15 k lilrocker sliding hitch
dgdekoekkoek3
im having trouble pulling the lever that unlocks the sliding part back far enough to activate the slider.it loks life the flat stock that attaches to the handle assembly is twisted where it slides into the slots on the end thanks
2 REPLIES 2
GreyHairedGeek
Sorry if this is of no use but on the LR hitch the handle points "up" to align the protrusion on the shaft with the channel in the outside casing the shaft slides in. Then you can pull out the bar into the "open" position to hitch up the trailer. Probably thought of that but when I got mine it took a few minutes to figure it out :)so I did not want to assume anything. Hope this is it for it will be a very easy fix. ๐Ÿ™‚
Also I drilled a hole into the shaft in order to place a safety pin to lock the handle in place as I am going down the road. Mine did not have a locking pin at all.
Fiverwheel
You must have the hitch looked at by a qualified tech to see if the lil rocker is still safe to use. It would be terrible if you lost your 5th wheel traveling down the highway!
2006 34' Monaco Cayman
