Mar-06-2014 11:22 AM
Mar-07-2014 09:50 AM
Mar-07-2014 09:43 AM
hone eagle wrote:
Shot in the dark -did not Teton 'drop' the front frame (sub frame?) for more storage ,maybe the I beam is above the 2" cross members?
Mar-07-2014 06:29 AM
Mar-07-2014 05:48 AM
Mar-07-2014 02:04 AM
Mar-06-2014 06:20 PM
Veebyes wrote:
Trying to understand what you are needing to do. I do not have hydraulic jacks but I have removed the legs on mine a few times so lifting is nothing new to me.
If you don't have a truck to use at all build cribbing under the pinbox & use a bottle jack to lift the front that way. Concrete block, not singles, with weight distributed with wood will do it. You won't need much lift distance to take the weight. Be sure the wheels are blocked. Don't want any moving surprises.
After the weight is transfered you are free to do whatever with the leg.
For the boat stands look in www.defender.com All kinds of other good RV stuff on that site too.
Mar-06-2014 05:30 PM
Mar-06-2014 05:15 PM
Mar-06-2014 04:44 PM
Veebyes wrote:
Leave it on the truck or, if you need the truck, block it under the pinbox.
Don't know where are but if you are near a boatyard you could borrow or buy an adjustable boatstand such as the one shown here. They are available in various height ranges.
Mar-06-2014 04:35 PM
45Ricochet wrote:
Nice RV, I came really close to getting one before we switched at the last minute for the one in my sig.
Anyway have you pulled down the underbelly cover and looked? I can't see mine either normally but you can remove a couple of screws on the outside to locate the I beams.
Good luck and be careful. I'd crib block it also.
Mar-06-2014 02:24 PM
Mar-06-2014 02:06 PM
