Everything I've read is you're really limited by your tires. I have a 2007 Chevy Silverado Classic 2500HD Duramax CCSB 4WD. I talked with a guy on the Duramax Forum and he said the weak link is tires. I have load Range E Bridgestone Dualer tires at 80# they are rated at 3042#. So if I'm figuring this right that's a total of 6084# GAWR for the rear. This sticker inside my truck door says the same weight My trucks owners manual says 14,200 for the DMax with a foot note stating 3000 King Pin weight for a 5er. So am I ok as long as I don't exceed those number? Should I take it to a scale before I buy it? Any other Elevation owners on here?
Thanks all.
Additional info dealer sent me the certified dry weight when it left the factory. The sticker says 11,572 lbs. :h
One more addition. I found a certified scale. My truck weighs 7880 lbs and rear axle is 3420 lbs.
TV 2007 Chevy 2500HD CCSB 4X4 Duramax. EFI Live, Edge insight, Sinister EGR delete
S&B cold air intake, Titan 52 gal tank, FASS 150 Lift pump, Magnaflow 5" exhaust
Andersen ultimate hitch
Air Ride bags
