โMay-31-2019 07:19 PM
โJun-01-2019 09:24 PM
โJun-01-2019 07:35 PM
โJun-01-2019 01:13 PM
โJun-01-2019 11:32 AM
Lwiddis wrote:
Test first! Never plugin anywhere without testing.
โSome motorhome designs are foregoing propane and are designed to be all electric.โ And how limiting!
โJun-01-2019 11:16 AM
KD4UPL wrote:Good advice.
A 50A RV outlet is supposed to be on a double pole breaker. It does have 240v available if wired properly. I would absolutely check to see that it is wired properly before plugging in. I always carry a volt meter with me and check every outlet I ever plug an RV into.
โJun-01-2019 08:03 AM
โJun-01-2019 07:54 AM
ACZL wrote:
Progressive Industry 50 amp EMS will tell you if ok or not.. Worst case, use a 50 amp reducer to 110 and don't use anything in coach above lights, fridge. Not sure about A/C or coffee maker.
Other folks thoughts?
โJun-01-2019 05:32 AM
itsabouttime wrote:
The 50 amp connector has two 120 volt sides, each rated 50 amps. They are on opposing legs and will measure 240 volts line to line. The top and bottom pins are ground and neutral. The sides each measure 120 volts to either the neutral or ground and 240 from one side to the other. This video gives an excellent explanation of the connection, both 30 and 50 amp. https://www.youtube.com/watch?v=GoOR2AJGjOI
Russ
โJun-01-2019 04:58 AM
โMay-31-2019 10:44 PM
โMay-31-2019 08:12 PM
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2005 Saturn Vue (Mr. Toad)
3.5L V6 Automatic
โMay-31-2019 07:54 PM
โMay-31-2019 07:52 PM
โMay-31-2019 07:37 PM
