5500 Onan quits after 1-2 hrs use, then starts back up
roller183
Was out dry camping this weekend with the ATV club and had a new issue with the generator pop up...
gen was running smooth and steady for at least 1 1/2 hours then quits like I turned it off...No fuel stumble, just like it was turned off..Would not restart right away..Wait for 2-3 minutes, start back up and will run for another 1-2 hours and stop...
The best code I could pull from it was a "34" ..Can't find a fault code list to save my life. Looked at Cummins page, nothing. Did searches no luck..
I'm hoping it is something simple like the last time where a rodent had chewed the wires....
Anyone have similar issues?
TIA. Checked the search engine here but probably used the wrong wording.
2007 Forest River Sierra Sport F 40 SPTS 40' 3 axle TH.
2013 RAM Mega cab Dually 6spd.auto gray
17 REPLIES 17
Dirtclods
Check your oil level.
AAA Motorcycle RV Plus
joebedford
Nomad II
Nomad II
A very quick Onan search came up with 34: high inverter temp
Debug from the op manual
Make sure nothing is blocking cooling air inlet or outlet
Reduce the number of appliances (could be altitude related)
cooper841
Sounds like fuel pump.not enough oil
Dana Cooper
Chipper(Lab)
2007 Fleetwood Fiesta LX
2003 Harley Fatboy mighty hauler lift
2010 Kia Soul
