5th wheel hitch lift
hornet28
I belong to three different trailering forums and don't remember where I saw a similar lift someone had built. I used the general idea of his and built this one. It fits into the hitch the same as the pin on the trailer. Lock it in place and use a cherry picker or overhead hoist to lift it and save your back. I just used what I had on hand
39 REPLIES 39
Dave_H_M
We all need "something" to do. Keeps the brain cells moving!
Me, I just backed the fifth wheel into the barn yesterday and left the hitch hanging on the king pin.
however i did spend some time fabbing up a muffler for the 1948 Maytag two cylinder opposed. ๐Ÿ˜‰
laknox
I found an eye bolt in my dad's junk pile, welded a 4" flat plate on the end of it, and used it just like you're thinking of doing. Found a cheap engine hoist to lift my Companion out in one piece then dropped it on a $10 furniture dolly from Harbor Freight. Sold the engine stand that came with the hoist, so was only out about $50, total.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Learjet
I see that B&W has their own lifting device.
https://www.bwtrailerhitches.com/product/fifth-wheel-lifting-device
you can buy them here
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
richclover
I installed a B&W Turnover Ball in my Ram Cummins. Topped with the Anderson Ultimate.
Seemed like the easiest way to go...
Rich
2019 RAM 1500 Classic 4X4 Hemi
2021 CanAm Maverick DS Turbo
Southern NV
hornet28
Way to heavy to lift and drag then lift and push. It was on a low cart with wheels, I rolled it next to the trailer, jacked it up and blocked it a few inches at a time. I used some 2x6 at the top to get it even with the trailer bed then I put some lengths of 1/2" pipe under it allowing me to roll it onto the trailer
4x4ord
Lift one side up, drag it over to the trailer and set it on the deck, then go lift the other side up and push.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
hornet28
No the trailer at the fenders is wider than the sleeper.
94-D2
Cribbing back the trailer under it.
2018 Ram 3500 Crew Cab Laramie 6.7L, Aisin, air ride, Ram puck prep, SuperGlide 20K auto slide.
2018 Bighorn Traveler 4 slide w/Apt.
Itโ€™s not what youโ€™ve done that commands respect, itโ€™s what you do.
Happy Campinโ€™
hornet28
Ok for you guys who feel the need to forgo lifts or such. Here's an example of working smart. In this picture is a 63" semi sleeper on my car hauler. I put it on there by myself no one around and no lift, hoist or fork lift involved. So how do you think I did it?
valhalla360
Nomad III
Nomad III
Another vote for just lift with the front of the trailer.
Alternatively not hard to tie it off with a rope and lift.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
cummins2014
Cummins12V98 wrote:
Construction career so I know how to handle heavy objects.
Same here 42 years as a steel worker , and it takes it toll.
Cummins12V98
Me Again wrote:
cummins2014 wrote:
Cummins12V98 wrote:
I just Man up and lift each pc in and out of my truck. Iโ€™m 62, last time I removed and installed I was 60.
Well you will get even smarter as time goes on .
He already did, he bought another 2nd gen RAM to haul stuff in!
Dang nice looking setup! Thatโ€™s my Summer ride and entertainment
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
Cummins12V98
ford truck guy wrote:
I few years ago, I " manned up" removing my super glide in 1 piece...
Went into surgery the following week to repair a hernia... Thats that last time I did that... Up till this past year, if I needed to remove, I broke it ( Superglide ) down to as many pieces as possible... Head...Swivel...2 way tubes...base...rails.... :S. Live And Learn
