5th wheel leveling jacks
Cromberg
There seem to be some electrical devices on my 5th wheel that work only on battery and some that work of battery and AC. I recently discovered that my leveling jacks don't operate even though my battery is successfully operating the slide-outs. Plugging into AC power did not change that. The jacks worked fine the last time I hooked up so what am I missing?
3 REPLIES 3
Dave_H_M
If you are talking about the stabilizer jacks like in the rear, maybe they sat and got all corroded up. I happen to know a guy that let his do that. :S
My stabilizer jacks have self resetting circuit breakers so you should hear some kind of click when you push the switch to go.
Once I got mine freed up and oiled they were happy.
agesilaus
There is a inline fuse in the wiring to the jacks, you should find that and check it.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
donn0128
The way it is wired. You need to start tracing the 12 volt side and fix it the way you want it
