โJul-14-2013 07:59 AM
โJul-15-2013 04:43 AM
โJul-14-2013 07:25 PM
MFL wrote:
My FW has the equa-flex suspension. I see no adjustment to raise or lower the equalizer. My spring end brackets have only two holes, the one the bolt is in, and one two inches lower.
I too, am doubtful that lowering the ends two inches, will actually raise the trailer two inches. I would just like to be as close to level as I can be, when towing.
Thanks,
Jerry
โJul-14-2013 06:41 PM
โJul-14-2013 06:21 PM
โJul-14-2013 05:36 PM
โJul-14-2013 04:53 PM
โJul-14-2013 03:19 PM
htowners wrote:I did mine the same way but also put my landing gear down for a little extra safety
I did mine last year in about 2 hours, including gathering and putting away my tools.
I did 1 shackle at a time, with my 5th hitched to the truck. Slightly support the trailer near where you start, remove the 1st bolt. Use a socket or wrench on the bolt head, to prevent rounding the shackle hole. Once removed I jacked up that corner, used a drift to align the hole, then drove the bolt through, which drive the drift out. Do not seat the bolt by tightening, drive it with a mallet, or better yet a press, else you risk rounding the hole (experience speaking here).
I'm planning on repacging everything with wet bolts soon, but be careful with the nylon bushings, they are thin and easy to tear (just an observation fortunately not an experience). It's much easier with a helper, but I did mine solo. Air tools make it a lot easier, too. I used a 2 foot piece of 4x4 between the frame and jack to spread the load.
I've towed a few thousand miles since and no issues. I'm still a little nose high, but nothing the equalizer can't handle.
Good luck!
โJul-14-2013 01:53 PM
Fulltimer50 wrote:
Dont forget that you have to lower the center equalizer part as well. You cant just lower the ends. Its a two man job.
โJul-14-2013 01:48 PM
โJul-14-2013 01:29 PM
โJul-14-2013 01:21 PM
NC Hauler wrote:larry barnhart wrote:
Kinda like in construction it is up for down and down for up.
don't worry about it NC Hauler we are here to hep ya.
chevman
yep..:B
โJul-14-2013 11:05 AM
chevman
โJul-14-2013 10:22 AM
