Almost Too Much Excitment
Impkitti
We just got back from a 3.5 week trip through Canada.
At one of our stops, I was guiding the DH in to our site and I noticed a weird mud patch on one of the tires. After he stopped, I checked it out. It was a bulging bald spot bigger than my two hands. We were very lucky it did not blow. I figure it would have on our way to our next stop.
At some point the brake must of locked up and we dragged that tire an undetermined distance. It was rolling when we parked, so it was a temporary situation. We had an extra day built into our schedule, so we did not loose any real vacation time finding a new tire and getting it installed.
For the rest of the trip, I inspected all the tires as we parked, and made sure they were rolling as we left site.
Ellen
1 Retired Husband
2 Dogs
2 Cats
1 2008 F350SD Truck
1 2012 Arctic Fox 29-5E
2 Cars
1 House
Not Enough Time
12 REPLIES 12
93Cobra2771
There are a couple of tire engineers on this board, and they can likely tell you what happened. My vote goes toward a broken belt or straight up tread separation.
I don't think you had a brake to lock up. I'm guessing a tire defect or damage of some type.
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
restlesswind
An out of balance tire can cause wear that looks like that in the picture.
If the wheels have been balanced,a thrown weight could cause it.
I know,there are some folks that do not believe in having trailer wheels balanced,but.....
'04 33.5 CKQG Hitchhiker Discover America
04.5 Dodge 3500 CTD SRW
Pac Brake,Max Brake
Fulltimers since '06
jffnkrn
we had this happen to us a few years ago. we had a broke or disconnected break wire which caused the other tire on the same side to lock up when we applied brakes. we did have a spot in the tire where the tread was almost gone. this was in two spots. when we hit the break at slower speeds, this is when the other one locked up. But like everyone said, get to checking so you don't have some major happening that will cause harm to you, others or the trailer. Good luck & Be Safe ! ! !
Impkitti
Dtank wrote:
On edit - seems "n7bsn" has hi-jacked the thread, complete with pics, but no solution to *his* problem/s..:?
N7bsn is my husband. Those are our tires.
Ellen
1 Retired Husband
2 Dogs
2 Cats
1 2008 F350SD Truck
2 Cars
1 House
Not Enough Time
Dtank
DesertHawk wrote:
Back in the earlier 2000s, we had a Football sized bald stop form one of the rear duallies on our MH. Not from the break locking up for sure. Tires can get worn in strange ways. Really don't believe yours was cause by the break locking up.
You ("lmpkitti") "had" a problem..:(
You may still "have" a problem!..:(..:(
Check the BRAKE system, suspension, etc. - before something BREAKS again.
IMO - don't believe your brakes were at fault either - you need to find out what's going on - and why...:h
n7bsn
Photos
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
n7bsn
Valkyriebush wrote:
I would be concerned why it happened and perhaps have the brake system checked too. Wheels should not be dragging. Temporary until you hit the brake some way again. I've had things fix themselves but I would check this issue out.
When the trailer was in the air I did some testing and couldn't get it to hang up again.
Next up is to tear the hub apart and inspect (and repair/adjust as needed)
laknox
Often time you'll see this from a broken belt that throws the tire extremely out of balance. I witnessed a badly OOB tire on a FW last year. LR tire was hopping a good 4" off the ground. Unfortunately, I didn't feel like running up to about 75 to try and warn the guy, as I was towing my own rig.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
DesertHawk
:CDesertHawk- Las Cruces, NM USA
*2015 Lance 1985~Casita de Campo~23' 4" Tongue to Bumper, Dinette Slide
160 watt Solar Panel/GoPower! Solar Controller
*2009 White Ford F-150 Reg. Cab
Long Bed with A.R.E. Molded Fiberglass Topper
*Previously~ 2005 16' Scamp
Valkyriebush
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
CarlT100
I am glad you spotted that before the tire blew and caused damage. Where in Canada did you travel. We have been in Milton, Ontario since April 15th amd are about to head up to North Bay.
Carl S
US Army Retired
'11 F-450, 6.7, 4X4, crewcab; '14 Fuzion Impact toyhauler
'12 Triumph Tiger 800XC; '03 Triumph Bonneville T100, 1968 Triumph TR6 Trophy 650cc
SWMBO: '13 HD Sportster; '06 Honda Big Ruckus
Golden_HVAC
You are lucky that you found he problem as you backed into the site!
Glad that the tire did not damage the side of the RV!
Happy travels!
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
