Andersen Aluminum Ultimate 5th Wheel Connection #3220
Seabeedaddy
All,
I want to purchase this, "Andersen Aluminum Ultimate 5th Wheel Connection #3220." But for the life of me I cant figure if EVERYTHING is included That is needed with "3220" Package or not.. Or if I need to buy Separate accessories?? Anyone have Experience with this?Where did you buy? I was looking at tweety's.
Also I have a 2016 F350 "fifth wheel Prepped" truck. What do I need to buy for the goose neck hole to work with this Set up.
Thanks all
Rob
4 REPLIES 4
laknox
Seabeedaddy wrote:
All,
Thanks all
Rob
While not all states require them, be sure to get a safety chain kit, because you just might travel through a state that requires them and, if a LEO didn't get his morning donut, can make you park your rig until you install them. The Andersen is considered a ball hitch here in AZ and chains are required for =all= ball hitches.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Sport45
The "Hitch Prep Kit" only gets the underbed part. If you also got the "Gooseneck Hitch Kit" you'll be good to go. Otherwise you'll have to get the Ball from Ford or Reese.
’19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
Me_Again
Assuming you have this http://www.amazon.com/Reese-30138-26-Reese%C2%AE-Under-Bed-Gooseneck/dp/B004R3BYII you do not need anything else, except safety chains, as it is a ball and coupler hitch. And a strong bed floor to carry the weight.
Chris
majorgator
I bought the 3221 model (lowered version) from Tweetys. Mine came with the hitch unit, the ball coupling adapter (that mounts to the king pin), and the standard coupling adapter (sleeve that connects to the GN ball). The newer models have a "funnel" on the ball coupling adapter. That's what will be included and that's technically all you need. Some may wish to purchase the safety chain package as well, but that's a separate item.
For the 2nd part of your question, the hitch attaches to the GN ball, so you don't need anything for the hole (the hole will have the ball).
SAVED BY GRACE, THROUGH FAITH*
1998 Coachmen Catalina Lite 248TB
TV: 1996 F350 Crew Cab 4x4 7.3L Diesel (a man's truck)
*signature amended so that religious components aren't included (per "Admin")...hooray, now nobody will be offended by my personal beliefs
