Arctic Fox 27-5L vs 28-5C
I'm looking into purchasing either the 27-5L or 28-5C model. My last AF was a 24-5N which we used for 15 years and about 80k miles. I'm interested in input from owners about the pros/cons of each model. We know they are heavy and more expensive but as we haven't had the usage of one yet, I'd like to know your thoughts.
TV mounted in the bedroom - is it pretty sturdy?
View angle of TV from the couch - is it comfortable? Does it severely limit the size of the TV in the living room?
No, TV isn't the most important thing, but we do watch a lot during inclement weather.
On the 24, we had no issues putting groceries away while in the parking lot of the store. It appears the 27's slide-out blocks the pantry as does the 28's. The 24's Owner's Manual states it is required to have the legs down and trailer level before putting the slides out. Is it the same with the 27 and 28?
The 27's we have seen have a sturdy stair system with strut assist. I think it is a MORryde, but not positive. The upside to this type of stair system is the stability of the stairs as you use them. The downside is the required almost 5' of side clearance when extending or retracting the stairs. If I'm at the storage lot, I won't have the clearance and would have to pull the trailer out to be able to get in. Anybody here have comments on their experiences with this type of entry?
Both come with a MORryde RPB pin box. I've never used one of these before. Good/Bad/Ugly?
We had a dinette in the 24 and, as it was just the two of us, two chairs. What were your preferences between the dinette and the L shaped bench seat in the 28 and why?
On the 28, it appears there is no room to access the kitchen (sink, fridge, pantry) while the slides are in which makes it difficult to pull into a spot for a midday lunch. Again, do we have to land the legs and level the rig before we open the slides to have lunch?
Thanks in advance for your input.
FMB
'15 RAM 3500 CTD Laramie Limited 4WD LB
'04 Arctic Fox 24-5N (Raisen) (Gifted in 2018)
