Bang! Woke up to my bedroom awning's spring letting loose
Sea_Six
I thought a tree branch or heavy object had landed on my awning just before dawn.
Got up there with a flashlight and found nothing had fallen, but the awning fabric was limp instead of stretched taut. The material looks ok, it's just not being stretched tight by the awning like it should.
Any possibility of repairing this, or am I looking at replacing the awning assembly?
7 REPLIES 7
tomkaren13
Sea Six wrote:
It turned out to be a broken torsion spring.
I paid an RV repair tech to replace it. The replacement spring mechanism was around $90.
Right choice! Been through that twice!
Your discription of something falling on the roof is right on!
Sea_Six
Swamp_Man
X2 what Peg Leg says. Be extremely careful. The spring tension is very high (it has to been to hold the fabic in place in the wind, etc). Find the manufacturer and see what their web site has to say about replacing the spring.
Steve & Trudy Jackson
2018 Cyclone 4005
2016 Ford F-450 6.7 PSD
AirSafe 25K hitch
Peg_Leg
Be careful. The torsion rod spring can hurt you. Working on a ladder isn't going to simplify or improve the safety of the process.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
harold1946
Google "carfree awning parts" and you will find sites with drawings and part numbers. www.pplmotorhomes.com carries many and reasonabley priced.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
Sea_Six
Sorry- 2001 model Jayco Designer. Don't know the awning manufacturer. I'll get up there again and look.
The main awning is made by Carefree I'm pretty sure, and the others are probably the same.
harold1946
What manufacturer and model number?
It could be the spring or just the pin that holds the tension. Hard to diagnose long distance.
Harold and Linda
W-22 Workhorse 8.1L
Explorer Sport toad
