beating a dead horse about tires, but have a question
DelawareCamper
I joined the "blow out club" a few years ago in 2009... New 5er, I'm thinking about getting tire sensors for the 5er... so I inflate to 80 lbs per tire,, I would assume I'm watching for both low pressure and high pressure... at what point would i become concerned, or at what drop or rise of pressure would I be over concerned,, is a differance of 5 lbs + or - or 10 lbs + or -... ?
21 REPLIES 21
OutdoorPhotogra
majorgator wrote:
stripit wrote:
DelawareCamper wrote:
donn0128 wrote:
TPMS is worthless if the tire throws the tread like lots of them do. There is no loss of pressure, but the damage is still done. Instead of spending money on that, I would first install quality tires.
Point well taken
Do not let this post keep you from purchasing a TPMS for your rig. The percentages of lost tread over blow outs/ tire failure, is minor and having a system makes your traveling less stressful, in my opinion.
TPMS is monitoring pressure. Blow outs, tread separation, and other tire failures are not always a result of loss of pressure. In fact, of all the blowouts I've ever experienced on our equipment and utility trailers, its not been due to insufficient tire pressure. In every case, I could hear and/or see it, so there was no lack of awareness of the situation. Better off just checking tire pressures during the trip, at stops, at the campground, etc. and don't spend your money on TPMS. Quality tires are a far better investment. I can see my tires in my mirrors, and you definitely should be able to tell the difference in how the rig is handling when a blowout occurs. Just curious, though, how anyone ever got along on their cars or trailers until the TPMS came around in the early 2000's...??
I had a blowout last year after dark. I did not hear it and it was on passenger side, harder to see in dark. My wife was following in trace and saw it. I see the value in a monitoring system even if it is an alert at point of the blow-out.
2008 Rockwood Signature Ultralite 5th Wheel
F-250 6.2 Gasser
Former PUP camper (Rockwood Popup Freedom 1980)
majorgator
Point well taken
SAVED BY GRACE, THROUGH FAITH*
1998 Coachmen Catalina Lite 248TB
TV: 1996 F350 Crew Cab 4x4 7.3L Diesel (a man's truck)
*signature amended so that religious components aren't included (per "Admin")...hooray, now nobody will be offended by my personal beliefs
larry_barnhart
Point well taken
There is no point to that comment but anything can happen very quickly.
I like having knowledge what our rv tires are doing and if a tire blew guess what!! I would know to get off the road instead of waiting for a horn to honk and get a wave something is wrong.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
stripit
Point well taken
Stacey Frank
2016 Tiffin Allegro Bus 40AP
2019 Tesla Model X
2015 Cadillac SRX we Tow
1991 Avanti Convertible
DelawareCamper
Point well taken
RustyJC
I have my alarms on the TST507 system we use on the truck and 5th wheel set at ~10% below and ~20% above cold inflation pressures for the trailer - perhaps a bit less on the high pressure alarm for the truck as it doesn't experience the pressure increase when hot that the trailer does.
That's probably a pretty good starting point - you may find that you have to adjust them slightly based on the unique operating characteristics of your rig.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
donn0128
