Best stabilizer help needed
6Gun
I have a new 31 ft. Rock-Wood and need to get the shaking under control when parked. My wife has a really bad temper when woke up in the early morning:S. There are so many products on the markets I'm not sure what works the best. I have a Side Winder king pin so I don't think a front tri-pod stabilizer will work. Maybe Wheel Locks?
I do have electric landing gear on the back it helps but its not great.
Thanks
24 REPLIES 24
Shepherd
Four point leveling system with strong arm are the best.:B
2018 Ram 3500 CC aisin/4.10
2014 Rushmore Monticello
relaxin
I found by usind some large or stacked blocking under the landing gear and rear stabilizers, and taking it up about an inch to inch and a half on the springs takes just enough wieght off the wheels to drastically reduce the bouncing, just a little side to side motion remains.
what I found also was setting up with a full tank of water and outside stuff still inside, as the weight of the unit changed the springs would lift the stabilizers enough to render them redundant, so if you have patio funiture and bikes or anything else more than a few pounds (which adds up) unload them first.
and no my unit did not twist up like a pretzel or fold up like a V amazingly enough
Relaxin, hikin, canoin, enjoyin life
headin down the road with a 29' reflection, canoe, camera, & hammock. 2022 GMC extended cab 6.6 litre gasser.
Rug rats grown and gone, just me and my beautiful little lady.
Dutch___Di
We too had tried the route of the Bi-Pod for years. Dutch even installed an additional set of arm jacks at the rear of our Carriage but neither worked for us. When we installed permanently installed aftermarket stabilizers over 7 years ago, my rockin` and rollin` disappeared and I have been a happy camper ever since. Di
2015 Western Brown Pearl single cab Ram 3500 Dually. Aisin Transmission, Pace Edwards auto rolltop cover, DeBoe Slide Step, AMP Side Steps.
1996/2010 Triple Slide Carriage, Mor/Ryde Susp, Kodiak Disc Brakes, Big Foot Auto Leveling System, TST TPMS
cummins2014
Thanks
All the stabilizers in the world won't stop all the movement, you are sitting on rubber tires ,and leaf springs . The stabilizers will prevent the fifth wheel from shifting back to front ,and side to side, but you will still get some up ,and down movement . If you want to stop all the movement you will need to get the weight of the leaf springs ,and tires . I have seen guys put jacks in front ,and rear of the tires both side just tight enough to take the bounce out of the tires ,and leaf springs. Personally the stabilizers work well enough for me ,but I don't have a mean wife 🙂
On edit : Steadyfast are very good stabilizers ,a little simpler in design ,and gets the job done very nicely
fj12ryder
JT Strongarms made a big difference in the stability of our tall, heavy toyhauler.
Howard and Peggy
"Don't Panic"
lpxguy
JT's for sure...AND put 6x6 blocks under the frt. landing gear so as to not have to extend them as much...worked for me...big diff.!!!
2005 GMC Sierra 3500 CC DRW D/A(FOR SALE)
2013 Crusader 335BHS TE(FOR SALE)
Alley_Fox
Are you using the BAL type between-the-wheel chocks? They help noticeably. JT Strongarms seem to have the best reviews, I have not tried them because our 5th wheel is very stable without LG braces. Also, when you drop the rear stabilizers, do you get them really cranked down? I bring my front LG slightly nose high and then crank the rears hard to make it level. Maybe that's why they call your model a "Rock-Wood".... just kidding...
2012 Arctic Fox 29-5T
04.5 GMC Duramax SLT CCLB turbo brake Isspros
B&W Companion, Tekonsha, EFI Live by Rob Coddens, Ride Rite air
5th Airborne
iawoody2
BB_TX wrote:
Forget the king pin tripod. Go with JT Strongarm or one of the other similar stabilizers for the front and rear.
We have JTs and they work great.
Another vote fot JTs, they just work.
BB_TX
hammer21661
JT's strongarm
2018 Ram 3500 SRW crew cab long bed 4x4 diesel Lariamie 1-2018
2013 fuzion 322.8/25/2012
2000 Yellow Lab mix Dog, Earl,The One who gave me Unconditional Love picked up 9-12 or 13, 2001 till 2-7-2014 may he r.i.p.
