Black tank flush 2009 Big Country
poisonivy
Hooked hose up to flush black tank, water showed up in floor of fifth wheel. What kind of problem do I have and how hard is it to fix. Any help would be appreciated. Thanks
8 REPLIES 8
blkdodge
Is it leaking inside the living area or the basement floor? I had one of mine leak into the basement and started pouring water out of the underbelly. Come to find out my garden hose had some screwed up threads on it and it didn't make a good seal, so the water was shooting past the connection and into the basement. Replaced garden hose with new and never had another problem.
2012 Dodge 3500 DRW/2012 Heartland Landmark San Antonio.
Me_Again
This is what mine looks like. Was behind a panel in the computer desk. Leaked the first time I used it. I bypassed it and installed a shutoff valve behind the inlet fitting. Chris
BB_TX
Yep, most likely that antisiphon/vacuum breaker valve. Failure of those valves is a common problem. If you are lucky it will be under the sink in the bathroom vanity cabinet. If not so lucky it will be inside a wall, likely behind the shower.
Look for something like this. Or it could be clear plastic.
Been there.
ependydad
12thgenusa wrote:
Might be the vacuum break valve. The flush water line has a loop in it that is positioned higher than the outside water flush connection. The vacuum break valve is located at the top of this loop. Mine is located under the bathroom sink.
Also called anti-siphon valve.
This would be my bet.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
12thgenusa
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar, Victron BMV-712, Victron SmartSolar 100/30, 200AH LiP04 bank, ProWatt 2000.
fivecodys
There is an anti siphon valve that might be leaking.
Mine was under the bathroom sink behind a removable panel.
If the water pressure is too high, they can leak around the fitting.
Good luck.
Bill
2007 Tundra DC 5.7L V8
SuperGlide 14K
Prodigy Brake Controller
2009 Flagstaff 8528RKSS Ultralight Series
Air Lift 5000
We have enough youth.......... how about a fountain of "smart"? :S
revflyr
You might have had one of the flush lines come loose, the main line from the outside splits into at least 4 smaller lines that are attached to the black tank to create the flush action. I had one come off and flood my floor on a 2006 cardinal. Had to drop the belly pan and the black tank to fix it.
sch911
Did you have the black tank drain valve open while you were flushing the tank?
That is a requirement. Otherwise the tank will fill quickly and overflow...
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
