I was using the scrubbers last time I dumped. I noticed not as much water was coming out of the tank as what I think is going in. We had very good water pressure at the campground so the flow should be much greater than I saw. No water was on the ground under the camper. I took my knife and punched a couple of holes in the belly pan, the under belly covering, and no water came out. i did notice some water leaking from the shower where the shower stand meets the linoleum floor in the bath area. I looked under the shower floor and the plywood was not wet. There was, however, water on the shelf behind the the dump valves. That was enough to use a towel to dry it up. Anyone have an idea what is going on?
thanks
Gary
Gary
Souderton, Pa.
'92 W350, 12V,5sp, 354's LS, cleaned up 3" pipe with turboflow. AFE filter, Autometer tac, Boost and (pre turbo) Pyro , #60 Boost(manifold pressure) for brake, pump bump and mods, 16cm housing,KDP jigged,33"BFGoodrich A/T radials,haulin a 12k fifth wheel,#60 exhaust springs, BD exhaust brake, Rancho RS9000X,Grant LTD with K40
