blank tank wont seal
Ropdoc
Hello all,
My 5th wheel is only 6 months old. I have flushed and flushed my blank tank but it will not seal. Every time I remove the cap off the end I have to have a bucket ready. I have been careful to make sure the handles are all pushed in. What else should I do?
Also has anyone else broken the handles off of the dump tanks? Mine slip in half. I've glued them, but does not last. I guess it is time fo metal custom handles.
Thanks,
Dave
19 REPLIES 19
GENECOP
spud1957 wrote:
Ropdoc wrote:
Hello all,
Thanks,
Dave
If you are unable to easily access your valve to replace it. This will work http://www.campingworld.com/shopping/item/twist-on-valve/27868. It will at least allow you to connect the sewer hose and eliminate the dreaded bucket dance.
Those are good to carry anyway, I always keep one In case of emergency....
GENECOP
Before replacing give a good thorough flush a try, just pick up the fitting that allows you to spray directly up the outlet while dumping, after dumping,,,try that first...
spud1957
Ropdoc wrote:
Hello all,
Thanks,
Dave
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
therink
I have had that problem 2 times early on when my rig was new. Both times, the culprit was debris that had lodged into the drain valve seat (namely baby wipes), not allowing the valve to close completely. I had to cut hole in belly coroplast to access the valve, remove the valve and clean the debris out.
This was not a fun job and needless to say that baby wipes are now banned.
I'm not saying this is your problem. It could be that the rubber Oring valve seal could be twisted.
In either case, you will need to enter the darkside to diagnose or repair.
If you have a dealer do it, they will likley charge you and arm and a leg if it is debris related.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
Mandalay_Parr
I would replace the valve.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
