โMar-22-2017 07:49 PM
โMay-01-2017 08:46 AM
RustyJC wrote:
Some of these "China bombs" have exploded while mounted on the unit as spare tires that have never been on the ground.
โMay-01-2017 06:48 AM
โMay-01-2017 06:39 AM
โApr-30-2017 07:53 PM
rhagfo wrote:Dannyabear1 wrote:
Do you read about many people having blow outs on their tow vehicles? Junky chinese tires are the problem.
X2!
We have had one blowout in like the last 30 years. It was a 10 year old Copper tire on our 89 F250, and it had a lot of miles in that ten years.
Getting ready to replace the LT's on our 5er as they are OEM and 12 years old. Just starting to show age cracking around the bead.
โMar-23-2017 01:54 PM
Whiskey River wrote:
fj12ryder I have no idea why some tires blow & some don't, just a suggestion.
Like you, my truck never gets used. It was new in May 08 & I still have original tires. It will be 9 years old in 2 months & has 39,000 miles or 4300 miles per year. Towing is probably 3,000 to 3,200 per year. The 5er was new in 08 and on 2nd set of tires. No problem with either set & they are ST tires...........
โMar-23-2017 11:40 AM
โMar-23-2017 10:22 AM
โMar-23-2017 09:50 AM
โMar-23-2017 09:38 AM
fj12ryder wrote:laknox wrote:From what I've read ST tires are not tested as rigorously as LT or passenger tires. So if you have a marginal tire it only makes sense to label it an ST tire.
So, an ST tire simply isn't designed to withstand all the twisty-turny stress when you have to back into a tight space? If so, why are they sold as TRAILER tires to be installed in an application where that's going to happen on a somewhat regular basis? Just sayin'...
Lyle
As far as an ST tire "designed to withstand all the twisty-turny stress when you have to back into a tight space", I think that can be strictly attributed to marketing hype. If you've ever examined a good LT tire right next to a "good" ST tire you'd never believe that the tissue paper thin sidewalls of an ST tire will withstand anything like the stronger sidewalls of an LT tire.
โMar-23-2017 09:11 AM
Lyle
โMar-23-2017 09:05 AM
Whiskey River wrote:The only time my truck gets used is when I pull my trailer. The rest of the time it sits, just like my trailer. I've had zero problems with the truck as opposed to the trailer. No flats or blowouts with the truck tires, the same cannot be said of the trailer tires.
Well I'll get in. I think RV tire's not being used is also part of the problem. Your pick-up or car in your garage or drive way gets used everyday, or couple/three times a week. The tires get heated up, cool down, heated/cooled, they get to flex and are not sitting in the same spot for 6 months or more. Now RV's, most sit most of the time, weather indoors or out. Couple trips during the summer maybe, then a thousand mile trip to Florida or Arizona and sit for 4 to 6 months. Some covered, some not. Some move during the seasons so as not to "flat spot" them, most not. And while sitting for 5 or 6 months, the air pressure drops and instead of having 80psi when parked, 5 months later the psi is 65. So RV tires are abused somewhat just by not being used.
And as SabreCanuck says, all the road debris may cause a weakening tire that blows 6 months later when you hit nothing. And the DOT's of all the states have not been able to design a bridge abutment or expansion joint to join the bridge to the existing ground does cause some teeth jarring moments.
โMar-23-2017 08:52 AM
โMar-23-2017 08:11 AM
โMar-23-2017 07:44 AM
