Awning Repair.
Forgive me for just jumping in here but we're on the on the road & you folks are typically very helpful. Anyway, I have a 35', KZ 5th wheel & a 19' awning. And apparently some bad wood because two, 1/4 by 1 3/4" lag bolts pulled out with a gust of wind.
Aside from tearing into the wall to fix the studs, I'm thinking of my options for a quick fix because it too windy here to leave it open too long.
I'm thinking of trying the old stuffing toothpicks in the hole as filler,
Maybe a 1/2" longer lag bolt & hope it doesn't go thru the wall.
Bite the bullet & put a bolt all the way thru the wall...
I'd like to try filling the hole with epoxy & drill, screw into that but time & conditions take that out for now.
Other ideas? be nice...
I'm also wandering how well will it travel if I just get the top bolts in loosely? The bottom bolts are good & the awning itself holds it pretty well up against the RV. Might hold well enough to get us to the next site that isn't so windy.
โ Did you see the
"Announcement : ★★READ BEFORE POSTING HERE★★" at the top?
Forum Posting Help and Support is reserved for questions related to "member" issues with Open Roads Forum sites. Signatures, profiles, photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread. Instead, visit the RV Forum which corresponds to the subject of your topic, and click the Post New Topic link. Thank-you!
Moved from FORUM POSTING HELP AND SUPPORT
