โMar-15-2015 04:07 PM
โMar-16-2015 06:43 PM
Allworth wrote:
That is what I did. 1.5"
โMar-16-2015 06:42 PM
โMar-16-2015 06:15 PM
โMar-16-2015 12:25 PM
Durango1500 wrote:
Thanks laknox. After looking my springs are already on top of the axles. So no flip needed correct?
โMar-16-2015 09:27 AM
Have not had to do a flip, but I've heard that it's not that hard to do, if you want to DIY, but a decent spring shop shouldn't charge you a lot to do it for you; there are kits from the axle mfrs to do this. Also, if you have more holes in the spring hangars/shackles, move them to the lowest setting and, while you're at it, install a set of "wet bolts". A wet bolt kit gives you bronze bushings to replace the plastic OEM bushings, heavy-duty shackles and grease-able (wet) bolts to hold the springs. Most people report much longer life and some even say their trailers ride better.
โMar-16-2015 08:47 AM
โMar-16-2015 04:00 AM
โMar-15-2015 08:00 PM
Wood chip wrote:
I hear the flip is actually pretty easy though.
โMar-15-2015 07:13 PM
โMar-15-2015 07:10 PM
โMar-15-2015 07:08 PM
โMar-15-2015 07:00 PM
Wood chip wrote:Durango1500 wrote:
Hi everyone my first post here. I have a durango 1500 and was hauling with a F350 long bed with companion with great clearance. I just purchased a 15 silverado 2500hd 2wd. I dont have the recommended clearance between the bed and camper due to how high the truck sits. I have my new e16 slider hitch on its lowest setting and not only does the trailer not sit level but there's about 4in of clearance. What can I do?
I dont want to beat up my new truck. I noticed by the leaf springs the is what seems to be a shackle with 3 holes. Will this raise the camper height? If so how do i do it. Im still new to campers so please forgive my ignorance. Thanks for any help.
I have 2015 chevy HD as well. I ended up content with 1-2" nose high on the trailer. My trailer already has the axel flip and my pin box and hitch are maxed out. My bed rails are 55-1/2" when I drop the trailer on it
โMar-15-2015 06:55 PM
โMar-15-2015 06:46 PM
