I thought about titling this “what now” but decided that my first reaction wasn’t descriptive enough. Can anyone tell me what is going on before I get a new power converter and/or transfer switch? When I returned to my 2004 Sunnybrook 5th wheel after 4 or 5 days, I found that the refrigerator (running on LP gas) had stopped working (ice melted), the light I turned on was dim, and the tank/battery panel indicated “poor” battery condition. The trailer had been left with the refrigerator on before without this problem. I started a generator to charge batteries and heard several clicks. This was a new sound, so I began looking for it. The clicks seemed to be coming from the transfer switch and the power converter was cycling. One click, and the power converter started (and I could hear the generator work harder), about 5 seconds later there was another click and the power converter fan stopped. This was repeated after about 10 to 15 seconds. Meanwhile, the AC system (plugs, TV, microwave, etc.) seemed to be working fine and the 12 volt lights were bright. So the generator was working and power was getting from the generator to the lights. I let the generator run for about ½ hour without apparent improvement in the battery charge condition. The clicking stopped when I put in charged up batteries, so I thought maybe one of the two original batteries had gone bad. I put them on a charger at home, and both were low, with identical 11.9 volt readings. They each took several hours to recharge, starting at 24.9 amps then declining to a float charge at a little more than 13 volts. They both held this charge for more than a day, so the problem is not a dead battery. My only guess is that the power converter isn’t able to recharge the batteries when they get this low. I have two 100+ amp-hour deep cycle 12 volt batteries connected in parallel (for 200+ amp-hours of 12 volt power), an IOTA ITS-30R transfer switch, and an INTELI POWER 9100 Model No. PD9160A power converter connected to a Charge Wizard to prevent overcharging.
JRMunn
