Mar-17-2018 08:22 AM
Mar-20-2018 05:59 PM
dpgllg wrote:
What I am trying to delay / prevent is the sun damage to the decals and finish. My old 5th wheel I ended up peeling off the decals because they were so bad. This unit has to last and I want to do everything I can within financial reson to protect it.
Thanks!
Dave
Mar-20-2018 08:59 AM
2012Oudoorsman wrote:
Got a perma pro for my 5er. Bought it mainly for the sun protection as our last camper became faded in 4 years. As described it's a unique material and I bought it knowing this. It fit well and installed quite easily. Straps all worked well. Where my camper was stored was dug out and had banks on both sides and a row of pine trees protecting it from the wind.
For 2 days I moved it so I could get the snow off and get it to the dealer. During these two days the winds were pretty constant and the cover was moving. I'd be quite worried about the damage to the paint if it was longer than 2 days. For this entire winter i have 1 little tiny spot that rubbed but extremely minor. I protected most sharp edges but forgot about the ladder. That is the only mark on the cover and it's more of a rub through than a cut.
Overall I'm happy that I bought it and it's working for its intended purpose and would buy it again. It should come with instructions on how to pack it back up not install it.
Prices for these cover are all over the place. I got th 40' long and extra tall version for about 400 through tweetys. Amazon was near 500.
Mar-19-2018 05:33 PM
Mar-19-2018 12:26 AM
Mar-18-2018 12:19 PM
TxGearhead wrote:
I had a ADCO for a previous 31ft 5th wheel. I real bear to put on. It ripped the first year. I think it's out in my barn. Unused for 4 years.
I have a Classic for the cabover. Not too bad to put on, but no picnic. I'm on my second one in 3 years. If it lasts a year it's good. But I keep it on all year. It's the model with a white top and grey sides, if that helps.
I hope to build a metal cover sometime soon.
Why can't you use the underground storage in the summer?
Mar-18-2018 12:05 PM
Mar-18-2018 10:34 AM
dpgllg wrote:If it won't stop the water..then it must be breathable.Thermoguy wrote:
I believe that is the cover that I purchased originally. I took it back because it did not keep water out, which is what I needed. If it is only for sun protection I believe it would be a good cover. It is more like parachute material so it is easy to install and take off. Looks like it would be hard to tear.
Thanks for your response. If it does not protect against water do you think it was breathable? I don't want water trapped underneath to cause mold.
Thanks again!
Mar-18-2018 10:08 AM
Mar-17-2018 08:51 AM
Mar-17-2018 08:44 AM
