clothes washer
dickens
what model clothes washer Whirlpool will work in 5th wheel
15 REPLIES 15
dickens
thanks so much everybody!!..very appreciative!!..I only ant a washer..not combo..have clothes thing at back we all made to hang off ladder..
Cummins12V98
My RV entry door is 27.5" in the clear. I removed the Chinese Made Whirlpool that came with the RV and replaced with a BOSCH 500 series apartment size washer that is 220V. It is AWESOME been using for two years full time. The whirlpool simply would not eject the water on final rinse all the time.
The US Made Whirlpool 220V dryer has been great with 3 years full time use.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
2oldman
DownTheAvenue wrote:
One that fits through the door and into the space made for it in the RV.
Yep, that's about it.
rbcamping
Are you looking for a whirlpool washer dryer stacked or only a washer? The stacked units are usually to tall.
DownTheAvenue
3_dog_nights
I bought a Danby from Walmart for about $450 used it for 6 years till I traded in the unit. Had an 11 gal tub. Would spin clothes out to damp, then would hang around camper at night, dry in the morning. Worked well. Highly recommend.
Bob & Lynn
2 Chihuahua's, Ella, Gracie
was-2013 Open Range 424RLS,06' Chevy 3500, dually, Duramax/Allison
also was - 2015 Winnebago Adventurer 37F, towing 2003 Jeep Wrangler
now - 2021 NoBo 19.5, 2019 Honda Ridgeline RTL (Talk about downsizing!)
djousma
I have stackable Whirlpool washer and dryer in my Cardinal, and they are apartment sized. I prefer the separate units vs the all-in-1 splendide. If buying separate, make sure the dryer is 120V, not 220V as most RV's do not have 220V available.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
donn0128
dickens wrote:
have an opportunity to buy whirlpool front loader slightly used
Unless its an aprtment size,how will you get in the door? RV doors are generally less than 24 inches wide.
donn0128
You need a small apartment size 120VAC. Splendid is the most common combo unit sole and used in RVs. Their small size makes them ideal for many folks. Be aware, unless your RV is prepped for a washer dryer your going to be oit of luck.
dickens
dickens
very appreciative for any help!!
dickens
so size s the only criteria..wondered if volts were an issue..on my own so don't know this stuff
2oldman
Spendide makes washers. Anything that will fit will work.
donn0128
If all you want is a washer, then you want the apartment size one. There narrower and have a smaller tub, so they will fit through the door. What are you going to do for a dryer?
