โJan-04-2016 08:34 PM
โJan-05-2016 04:38 AM
Old-Biscuit wrote:
One register partially blocked should NOT cause issue.
If air flow to/from furnace (registers/return air) are blocked sufficiently furnace could overheat.....if it does high temp limit switch will shut if down (safety feature)
SO give it a try prior to trip. Best to find out now so alt. plans can be made.
Might want to throw rug over that register so the material on slide bottom does not have warm air blowing on it.
We have a magnetic sheet (craft store.....cut to fit) on register in kitchen floor and a throw rug over that cause register is in a stupid spot. Been that way for 7 yrs. no issues.
And we do run furnace when we travel in cold weather
โJan-05-2016 02:07 AM
โJan-04-2016 10:26 PM
โJan-04-2016 08:57 PM
