Dehumidifier Recommendation???
bowler1
Hi,
I am looking to get an electric dehumidifier for my 41 foot 5th wheel. I think I have about 425 square feet total. Any recommendations?
thanks for your help
Matt
8 REPLIES 8
Bumpyroad
just saw some at walmart. $200 and $239 IIRC.
probably come off the same line in China as those costing $500.
bumpy
Fire19
Do not get the cheapest one out beware they are cheap for a reason. We have been out of our stick built since Jan 1st when our Cheap dehumidifier (2 yrs old) caught fire and smoke and sooted the whole house we are down to studded walls. Look at the Consumers reports to find a good reliable one.
2000 Ford F-350 Dually Crew Cab
2002 Gulfstream Seahawk 29FKS
1998 GL1500SE
path1
We had 3 or 4 over the years. They all did the job but the best one for me was one that was flat on top. Put it right next to my chair and the flat top worked perfect for "end table". Also get a couple gauges so you can see if its doing its job through out your rv, not just close it. I use 3 of these in different spots. They are for cigars storage boxes but work great to check humidity. https://www.walmart.com/ip/Xikar-Digital-Round-Hygrometer/713812767?wmlspartner=wlpa&selectedSellerI...
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
2oldman
Not hot enough to run air?
donn0128
Search online for ratings and pick the biggest one with the highest rating. You wont go wrong. Pump? Naw, dont need one. Set it on a table with the hise sticking out a window. Done!
Isaac-1
My solution is to put it in the shower and let it drain to the 40 gallon gray tank.
gbopp
Get one with a pump. You can drain it out a window or into a sink.
It's much easier than emptying the tank one or two times a day.
Isaac-1
Whichever one you can find cheapest in your local big box store
