Do you grease or lubricate the jack legs?
KATOOM
Does anyone grease the 5th wheel jack legs? Not the outside but the screw portion inside the legs which are doing the work lifting the trailer?
If so, how?
18 REPLIES 18
agesilaus
I give them a light spray with silcone or some other dry lube to make them slide up and down easier. Grease or oil on the exterior would attract dirt and grit.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
Ed9824v
never greased mine and do not have a zerk fitting that I can see, I would like to and prefer to but see no easy way
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
CarlT100
I did with my previous fiver; but I have not done so with my new one. I had to disassemble everything to grease them. I used white lithium grease. It was task; but I never had any trouble with the landing gear.
Carl S
US Army Retired
'11 F-450, 6.7, 4X4, crewcab; '14 Fuzion Impact toyhauler
'12 Triumph Tiger 800XC; '03 Triumph Bonneville T100, 1968 Triumph TR6 Trophy 650cc
SWMBO: '13 HD Sportster; '06 Honda Big Ruckus
TomHaycraft
Mine have a zerk fitting at the top of each leg. I hit mine with a few shots twice a year when I lube the wet bolts. I've had the trailer in my signature for 3 years now, used at least once a month since purchase, 12 months out of the year. So far, so good, smooth and quiet operation.
2013 Silverado 3500HD - Duramax/Allison - CC, long bed, SRW, 2WD
2017 Grand Design Reflection 303RLS - TST 507 TPMS
