Faded gel coat help
jgrassano
Good evening. New member here. I have a 2013 Montana high country and I just recently had it buffed and it still doesnโ€™t look as good as I was expecting. Is there anything I can do other than painting to get it looking nice again.
19 REPLIES 19
Veebyes
Not enough info. Was it simply buffed with a cleaner wax or was it done in two stages by compounding to get the chalkiness off then sealed with a high quality wax or sealant?
Due to cost & weight of gelcoat I can't say that I have ever seen a good gelcoat on RVs as can be found on upper end boats.
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
bshgto1
If your color is the gray finish they had back then you can forget ever cleaning it up. I had that finish and wax and buffed the unit till I was blue in the face and the oxidation came back in 3 weeks time. Finally sold the High Country cause I was just tried of dealing with it.
2018.5 Montana 3791 Rear Den
Electric brakes suck Disk brakes it`s the only way
Andersen Ultimate on the pucks, 5th AirBorne Mor/ryde SRE 4000 X Factors....real smooth ride
2018 Ford F350 Dually 6.7 Top Dog 5595 payload
B_O__Plenty
Gel coat just doesn't hold up. In time it all fades. Try a big truck repair shop. They will usually have a large enough paint booth to do the work. I've had two of my fivers painted. Front cap should cost under $2,000. anything more is a rip off.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
Tom_Barb
Many times when an old paint systems are buffed they will remove the clear coat. it can be replaced. 600 wet and dry sanding to prep the surface and reapply.
If you have a real gel-coat finish and it doesn't look as good as it should, have some who knows how to refinish gel-coat re-do it.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JL toad.
valhalla360
Nomad III
Nomad III
Paint...key item with paint: It's all about the prep work. Get all the wax off and fix any dings or it will show up after you paint.
Check with body shops or boat yards if you want to farm it out.
You can DIY, we did our boat several years back used Interlux Brightsides. 3yrs later when we sold, it was still shiny with no waxing or buffing. There are more durable paints (awlgrip is the most popular) but they aren't very DIY friendly. Interlux had the advantage that it was really easy to touch up if we did get a scratch.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
