Fifth wheel brakes
Rwake901
This is my first 5th wheel and I have a question about the brakes. The brakes on the 5th wheel do work but should I be able to lock up the brakes with the gain on the brake unit adjusted up all the way or is it normal not to be able to? Thanks
13 REPLIES 13
buc1980
On the heavy FW will be hard if you don't have disk breaks.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
Edd505
when were the brakes adjusted last? Mine don't lock but you definitely know they are on. You don't say what the TV is, built in controller or after market?
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Terryallan
stickdog wrote:
I was told if your brakes are adjusted properly you should set the gain at 50% in a safe area drive to 20mph and stomp on the pedal. If your trailer brakes lock reduce gain, if not increase gain and repeat and continue to increase the gain till they lock at 20mph. You then want to back off to the previous gain where they didn't lock at 20mph. As the brakes wear you will need to either adjust the gain or the brakes.
You don't really do that do you?. The correct way is to pull the brake LEVER on the controler. Not stomp the pedal.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Rwake901
fj12ryder wrote:
I cannot lock up the brakes on our 15,000 lb. triple axle toyhauler, never have been able to. It seems to stop well enough so I don't worry about it.
This is kind of where Iโ€™m at. Yes they will stop me ok but I would have thought with the brake unit turned up all the way it would lock up the brakes. If this is normal then I wonโ€™t worry about it. Thanks
fj12ryder
Howard and Peggy
"Don't Panic"
the_bear_II
Our 14000LB 5th wheel brakes will not lock up no matter how hard I step on the peddle or use the lever even with the gain all the way up. I did find that the electronic controller on my new truck engages the brakes significantly stronger than the old hydraulic actuated controller I had on my old truck.
With the old truck I was very unhappy with the trailer brake performance. I had checked the amps at the trailer plug, re did the brake connections, adjusted the brakes and nothing made much difference.
With the new truck and the electronic controller the very first time I engaged the brakes they came on much stronger. I am happy with the trailer brake performance using the electronic controller.
lenr
With the same truck and built in controller, I could lock a bumper pull with 3500 axles and a flat bed with 7000 axles=--both ALKO axles. A small fifth wheel with Lippert 4400 axles and a larger fifth wheel with Dexter 5100 axles could not be locked up and did not engage well enough to carry their share of braking with the controller on full. In fairness, the Dexters were not set in because I took the trailer straight to an axle shop and had disc brakes put on. They lock up now and the controller is set on 6.5. I don't want to make this about brands--there is another thread doing that. I did replace the 4400 axles with 5200 axles to get 12" drums. When that didn't help enough I had the backing plates changed to Dexter 7000 lb brakes. All that helped, but the trailer still didn't brake its share. With several different trailers, I dramatically increased the wire size going to the brakes with improvements in every case. I am beginning to wonder if the axle manufacturers are doing this on purpose to prevent folks from being able to lock up their wheels in a panic stop (which defeats braking.) Personally I would rather be able to adjust the controller to do its share.
stickdog
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
PNW_Steve
Towing my 36' - 5er I run the gain below 50%. If I turn it way up I can lock the trailer with a firm step on the brakes.
I did buy one trailer that I couldn't lock up the brakes. Then I figured out that the previous owner had disconnected them under the trailer.
As long as your trailer brakes are providing agressive engagement I wouldn't worry about not being able to lock them up. Just make certain that they are in fact providing the braking that you need.
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
Old-Biscuit
Depends on 5th wheel weight
Depends on condition of brakes/shoes/magnets/DC connections
Depends on whether brakes are properly adjusted or not
Depends..........
valhalla360
Nomad III
Nomad III
At low speed, yes but not at high speed.
You do feel a strong pull even at highway speed if you pull the lever.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
twodownzero
I can lock up my empty car trailer but not my 5er. Maybe mine need adjustment.
PNW_Steve
I am no guru.
I can tell you that I have owned half a dozen trailer brake controllers and about as many trailers. On the every one of them I could lock up the trailer brakes if I turned the gain up to high.
