floor squeak
clotus
In my 2015 Sundance 245XLT I have a spot in the floor near the bed that squeaks when I step. The spot is right where the carpet meets the vinyl flooring on the carpet side. There is a little flex where it squeaks. It is super annoying. Any idea how to fix it? Sign of a larger problem? Thanks.
Current: 2017 Winnebago 31K
(Sold): 5th wheel: 2015 Heartland Sundance XLT 245
10 REPLIES 10
Cummins12V98
1ofmany wrote:
clotus wrote:
Cummins12V98 wrote:
I thought we had a floor squeak. I showed the tech at DRV. He said it was the metal floor register. I gave him the death stare in disbelief! He said he was serious. I checked it out and it's true. He said these all do that.
What is the metal floor register?
Probably the vent heat comes out of when the furnace is on....
This is correct.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
clotus
MWJones wrote:
Drill a pilot hole through the carpet and floor material -stop before hitting the joist. Screw in a 1 and 1/2" screw. That will stop the movement. The screw will go into the carpet enough to be pretty much invisable.
Worked for me.
Does the screw go into the joist?
1ofmany
clotus
larry_barnhart
If you can see the floor from the basement glue a 2x2 to stiffen that area if possible.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Cummins12V98
MWJones
Worked for me.
M Jones
American and Texan by birth
Christian by the Grace of God
Retired and enjoying Traveling and Camping
Spending part of summers in South Fork, Co
rhagfo
We have a spot like that wood over Aluminum framing likely need a bit of talcum powder between the two.
clotus
GrumpyandGrandma wrote:
Probably a seam in the plywood/chipboard flooring or it could be a loose staple/screw.
It's definitely a seam. Any idea how to quiet it down?
GrumpyandGrandm
Grandma in front of her retirement home..
She lets Grumpy drive!!
