Mar-22-2014 09:55 PM
Mar-25-2014 07:22 AM
avvidclif1 wrote:
Oops
Mar-25-2014 07:06 AM
Mar-24-2014 09:47 PM
ah64id wrote:avvidclif1 wrote:
There's something different as the F350 shows 1080lbs more capacity. Maybe its not a misprint as larger axles could account for the difference.
Yeah the stickers are different, it's a sales thing an F-250 has to be rated less than a F-350 SRW.
People want to perceive the difference so it's put on a sticker, Dodge and GM do the same thing. Dodge and GM don't even switch axles for a DRW. A 2500 diesel has the same axle, with the same AAM weight rating, as the DRW CTD.
It's been proven time and time again how few differences actually exist.
Mar-24-2014 09:00 PM
ah64id wrote:jpjulian wrote:
I was a weight cop for the state police for a long time so am very conscious of the various weight issues.
As a weight cop what could you ticket for?
Everything I have read and heard from local cops is registered weight and tires.
With the proper tires a F-350 will have a 7180lb RAWR, for the same axle/tire rating as your F-250.
Mar-24-2014 08:47 PM
jeldridge97 wrote:
Joe,
Here's the info from the door jam on our 2013 F350 Diesel 4x4 CC SRW.
Front 5600
Rear 7000
CCC 3429
The truck has Michelin LT275/65R20 tires.
Jerry
Mar-24-2014 08:28 PM
Mar-24-2014 05:35 PM
Mar-24-2014 05:17 PM
Mar-24-2014 04:52 PM
ah64id wrote:
Here is where the misprint looks to have come from. It appears to be a spacing issue as the bottom specs are for a Dana 80, and are missing from under a Dana 80.
Mar-24-2014 04:07 PM
Mar-24-2014 01:05 PM
Mar-24-2014 12:57 PM
BB_TX wrote:ah64id wrote:
What if the 250/350 uses the same axle? It does, BTW.
According to Ford web site:
.............................................................F250....F350 SRW
Axle Shaft — Spline Minor Dia. (in.).....1.36.......1.50
...........— Spline Major Dia. (in.)............1.50.......1.57
...........— No. of Splines (Hub End)..........35.......37
So the axles are not the same.
Mar-24-2014 12:56 PM
BB...all Ford F250 and F350 SRW trucks are equipped with Sterling Axle Plant manufactured axle assemblies...These are assembled in the Sterling Heights Axle Plant nearby...and which has my BIL as the number two man in the entire building...my information comes directly from him...they are the same exact assemblies shipped to the Louisville Assembly Plant with no designation as to which of the SRW series trucks they may be mounted...
The larger axle diameter you mentioned only comes on the F350 DRW trucks which are equipped with the Dana manufactured axle assembly. This confusion continues even today because Ford has not fixed the mistake in the specification publishing...maybe some day Ford will fix the mistake...
Regards
Mar-24-2014 12:52 PM
