2007 WW FSW 3200
The fresh water drain manifold on rear tank is leaking were it connects to the tank.
A pipe comes out of the tank and has a slip type fitting with a hose clamp and some type of white rubbery gasket material bulging out. The drain manifold pipe stuffs into the pipe coming out of the tank. A steady stream of water is running out of that connectrion. If I push the drain manifold into the tank pipe farther, the leak slows or stops, but as soon as its let go the water pours out again. The clamp is as tight as I can get it.
Never seen a plumbing fitting like this.
Haven't had the chance to take it apart yet, wondering if others have had this problem and whats a good fix for this..?
2007 WW FSW3200
RZRS k&t Turbo
2 LT500
1 Lt500 hybrid
F350 CC 6.7PS Platinum
