Fridge problems
mudmaker
What is the telltale sign that a fridge loses its coolant?
Working on a Dometic 2852 that goes through all functions, thermistor tests at 9300 ohms. Gas ignites. Fans come on. Was on electric when it was discovered it wasn't working. There is 120 to the board I believe.
I'm thinking it lost the ammonia coolant.
Are there any signs like a stain of some sort?
Thanks
Glen and Loretta
Marc, Jake, Kirsten and fur kids Dexter and Bernie
2017 KZ Venom 4114TK Toy Hauler
2015 GMC Acadia
15 Silverado 3500 SRW quad 6.6 Duramax
11 Silverado 3500 SRW quad 6.6 Duramax
12 REPLIES 12
ScottG
If it has run off level much, it may be clogged up. If that happens, there's no amonia or other tell-tale signs.
I think you made the right choice.
mudmaker
Old-Biscuit wrote:
mudmaker wrote:
Found one at camping world. On the way to pick up and install today.
Lot of OTHER components could be the issue vs cooling unit
Blown fuse(s)
Bad circuit board
Dirty burners
Bad spark electrode
Etc etc etc etc
Did you even go thru the troubleshooting guide in manual LINKED
Never mind.......
So going to your troubleshooting page you provided, copying and pasting the part that pertained to my issues, going through each one and testing the unit in each circumstance and still not finding an answer.
Glen and Loretta
2015 GMC Acadia
larry_barnhart
I am guessing here but you did not know the answer to your question. that is ok but you are going to install the rear cooling system yourself?
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Old-Biscuit
Blown fuse(s)
Bad circuit board
Dirty burners
Bad spark electrode
Etc etc etc etc
Never mind.......
mudmaker
Glen and Loretta
2015 GMC Acadia
laknox
Could be internal contamination, a flake of rust or a little piece of solder floating around. One thing I've heard about is "burping" a fridge. Basically, remove the fridge, turn it upside down for 24 hours, then reinstall. It will either work, or it won't. If not, it's more'n likely toast. You can buy a replacement cooling unit for about $600-800, last I knew.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
mudmaker
Feel like I'm missing something or overlooking a step. I don't know though.
Glen and Loretta
2015 GMC Acadia
mudmaker
Oh and no yellow cake. Been looking for signs of that all morning. No smell either.
Glen and Loretta
2015 GMC Acadia
mudmaker
Ventilation yep, good breathing going on. Two fans running on and off via a thermostat
Leveling yep, its good.
Ambient Temperature about 68 outside
Air Leaks nothing to note
Thermistor checked. 9300 ohms
Cooling Unit ??? Don't know. Burner works. 120 element shows proper ohms.
I think I have everything but actual info on cooling unit. Thinking this is the problem and from what I've seen, not an inexpensive item to replace.
Glen and Loretta
2015 GMC Acadia
MFL
Nomad II
Nomad II
newman fulltimer wrote:
a yellow coating at the burner
This, and you can smell ammonia, if it is leaking to the point of no longer cooling.
Jerry
Old-Biscuit
Lingering ammonia smell.....loss of DC......lack of cooling etc
Without more info.......guesses so here is a manual YOU can peruse
Service Manual...pg. 5 troubleshooting tips
newman_fulltime
