Furnace power question
stro1965
Fall is just around the corner, as is deer season, so I have a dumb question. Can I run my furnace on 12v and propane or does it require at least 110v? I have a generator but I'm curious if I need to leave it running while I'm away from the camper. Also, are you guys sleeping in your rigs with the generator running all night? I understand the safety concerns, just wondering what others are doing.
2018 Ram DRW 3500 6.7
2019 Keystone Alpine 3021
16 REPLIES 16
stro1965
CarlT100 wrote:
Yes it can. But if I were going to reroute mine, I would route it up to roof level. There are kits for this.
I will look into this, thanks!
stro1965
2oldman wrote:
stro1965 wrote:
My concern with this particular generator is that the exhaust comes out right between the slides on the driver side. Can the exhaust be re-routed under the length of the unit to come out back by/under the ramp?
If this is just to run the furnace, it's like swatting a fly with a bazooka. The furnace motor is only 100 watts.
Exactly why I asked. Thanks!
pianotuna
Nomad II
Nomad II
8.3 amps for my furnace. Battery capacity may be lower during winter temperatures. It all comes down to duty cycle.
Regards, Don
2oldman
CarlT100
Carl S
US Army Retired
'11 F-450, 6.7, 4X4, crewcab; '14 Fuzion Impact toyhauler
'12 Triumph Tiger 800XC; '03 Triumph Bonneville T100, 1968 Triumph TR6 Trophy 650cc
SWMBO: '13 HD Sportster; '06 Honda Big Ruckus
CarlT100
I have three small portable electric heaters to supplement the furnace. Of course, that requires running the generator. In temps in the 20's, I used a tank of propane per week just using the furnace. Using the heaters, I used one tank in two weeks. Using the electric heaters requires shore power or the generator.
Carl S
US Army Retired
stro1965
CarlT100 wrote:
My generator is well sealed. I have slept many nights with the generator running. Just make sure your CO detector is working - even if you are just using your furnace. I have run my generator both for ac and to recharge the battery in cold weather.
stro1965
pianotuna wrote:
Add a fan based electric heater and it will save on propane use.
stro1965 wrote:
I will have access to 110v to keep the battery charged, just don't wanna use the gen if I don't need to use it.
I have an electric fireplace, that'll help if it gets as warm as the one in my last 5er.
CarlT100
Carl S
US Army Retired
2oldman
To charge batteries for nighttime furnace use, yes.
pianotuna
Nomad II
Nomad II
Regards, Don
Old-Biscuit
Fire it up NOW and make sure it works
korbe
Our furnace fan uses 6.7 amps while on. Just a helpful number to figure things out for us.
stro1965
