Generator / Carb Part description or number?
BigDogF250
After much diagnosing I determined the problem with my Onan 5500 Gold was definitely the carb. An upcoming trip prompted me to replace the entire carb, Amazon shipped me one two day Prime for about $250. Idles and runs like a champ.
I'd like to try replacing the bottom fuel regulator on the old one and see if that fixes the problem so I have a working spare. Does anyone know what that part number is or have access to a diagram? It's the part at the bottom that controls fuel flow from the bowl to the carb, it has a single two wire connector that goes into it.
Original symptoms were stalling for lack of fuel, it ran perfectly if I gave it fuel through the carb (carb cleaner). Because of that I think the rest of the old carb (jets and passages) is fine.
Thanks in advance...
PS: I ordered : Cummins 5410765 Onan Carburetor Kit from Amazon.
Don't take life too seriously, it's not permanent.
06 Weekend Warrior FSC3200, Axles flipped, Bridgestone Duravis Tires
2005 Ford F250 PSD 4x4
07 Yamaha YZF450 White/Silver, 94 Husqvarna WXC610
2008 Polaris RZR 800, 2011 Honda CBR1000RR & one Goffin Cockatoo
6 REPLIES 6
BigDogF250
That's the one, thanks!
bkirkpatrick
mrxlh wrote:
You are referring to the anti-backfire solenoid. Just remove it and cut the needle off with a pair of dikes, the solenoid is around $70.
It is actually called a fuel shutoff solenoid and I believe this is what you are looking for: EBAY
mrxlh
Ryan
2008 Ford F350 CC LWB Dually
2011 Raptor 4014LEV
2006 H-D FLHX
2010 Honda Rancher 420ES
Yellermanx
I don't know the official name but I believe it is a fuel cut off so the engine doesn't run on "diesel" or suck fuel in the engine while it's still turning over while shutting down. I assume it's 12 volt so to check it you should be able to touch the housing to the negative pole of a battery and the wire to the positive and see if it energizes (sucks in).
BigDogF250
That's actually what I did in troubleshooting, everything else works fine, it's just that it's not getting fuel through the bottom. Since it's an electric activated plunger I wanted to replace it in case it's electrical in nature, it's really clean at this point because it sat in Seafoam for almost 2 weeks.
64thunderbolt
What I did was soaked my old carb in a coffee can filled with seafoam after taking it apart. 3 days later I blew everything out with compressed air. 6 months later my friends carb got gummed up so I gave him my spare and took his old one. My spare has been running fine for him about a year now. He is now a true believer in seafoam as I had been telling him to use it. I took my gen to Cummins because it was throwing several codes. It would start but shut right down. Replaced the carb. What it was doing ? when it started the butterfly would stick and the eng would over rev spiking voltage and it would shut down. I now have another spare but using seafoam religiously will prevent this from happening again. Sorry for the lenghly reply but just take youe old one apart and do what I did & I think it will be fine. The reason my orig was gummed up is it had sat for 4 yrs prior to me buying it. Good luck.
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
