Generator choices
austingta
I need to buy a generator to work on a jobsite really soon. I need to power my Lincoln 230VAC which draws around 25 amps. Mostly it will be for camping.
Obviously, a good 7500-watt stand alone genset will do it, but they are too loud for lots of campgrounds. Is there a reasonably priced inverter style generator that offers 230VAC and 20-30 amp service? When I go camping, I'd like to have a quiet genset but I'm not sure it's worth it.
Frank Brooks Austin TX
2018 F 150 King Ranch max tow package with 3.55 gears
Published towing weight limit 13200
Payload per sticker 1464
19 REPLIES 19
garyemunson
If you can get past the price, big Hondas will power whatever you need and be quiet enough for campground use. There is a reason they are so expensive..they are the best.
byronlj
My Yamaha 6300 ran my Hobart 190 mig welder on 1/4" steel easily. I bought it years ago before the price skyrocketed.
It runs both my AC's in the fifth wheel. It ia big so I mounted it on the rear of my 5er.
Dave
byronlj
2013 Dynamax Trilogy 3800RL
GordonThree
Onan should have one to fit your needs, with a diesel Cummins motor in it. Going to be pricey though.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
austingta
romore wrote:
That is a pretty heavy and bulky generator for camping. Honda makes the EU7000is but the price may scare you. Can you consider a 2,000 watt inverter type unit for recreational use and leave the big one at work?
I don't think a single 2000W inverter gen will run my AC if I'm without shore power (and that might be important down here). I'm trying to avoid buying two different generators.
romore
