โAug-19-2013 03:42 PM
โAug-27-2013 07:48 AM
Vulcaneer wrote:goducks10 wrote:Vulcaneer wrote:
I happen to think that GY Marathons, should be replaced ASAP. And nobody should be running ST Tires. Any Chinese made tire needs replacement with non-Chinese tire.
LOL. Really based on your opinion or have you actually used them.
Both...When I say, "I happen to think" it means that is my opinion. My opinion is based on many years of my experience. All used with very good maintenance. And yes, I have used USA Marathons, and Chinese Marathons. On my 5'rs, and also on cargo trailers. The USA tires were better. But the Chinese marathons, have had serious issues. None went more than 3 years without blowouts on several. Most gone within two years. The others were replaced, before they could cause more damage to my trailers. I have had problems with any Chinese ST tire, I have used. Then I finally wised up, and gave up on Chinese tires. Haven't had tire problems since. My choice is LT tires made in USA or Canada.
โAug-27-2013 06:21 AM
โAug-26-2013 06:27 PM
Ginther wrote:The Weekenders wrote:
Check out this link about GY Marathons from the Montana Owners forum this week. clicky
Have to be registered to see that forum.
โAug-26-2013 06:22 PM
smkettner wrote:Ginther wrote:
Anyway... I found this Marathon Inflation PSB
I've been running them at 90psi and so far we've put nearly 2000 miles on 6 separate trips in 100+ degree Texas heat without any problems.
Fingers crossed.
I don't think the PSB says OK to exceed max sidewall cold inflation pressure.
It would appear to say if your tire placard(gvwr sticker) says 65psi you can go 75psi however I think that assumes your sidewall says 80psi max.
โAug-26-2013 06:16 PM
โAug-26-2013 06:09 PM
Fingers crossed.
โAug-26-2013 06:03 PM
โAug-26-2013 05:43 PM
โAug-26-2013 03:29 PM
โAug-26-2013 02:59 PM
โAug-26-2013 12:20 PM
โAug-23-2013 01:48 PM
โAug-23-2013 01:29 PM
broark01 wrote:Just curious how you account for the several posts on here about spare tires blowing up while they aren't even mounted on an axle...I think the Chinese are capable of making a good product, but the manufacturers are more interested in a cheap price. When it comes to cheap nobody is better at it than the Chinese.
My opinion based on my experience and watching others is that most tire failures are human failures in regards to care and maintenance. Tires are tires, maintain them and do not exceed their speed or capacity.
If you are leery about Chinese made stuff, rip out all of your electronics immediately. We vote with our wallets and we have voted for China and India.
โAug-23-2013 12:54 PM
