Had a bad blow out .And tired of reading 1000 post on tires
carpetguy2
Blow caused me 2700.00 in damage.Now ordering parts and have to get 235/80/16 tires.Rims got scuffed but good.Forest river will only sell rims with tires on them. So need tires and rv repair shop said michelin or goodyear.
I HAVE BEEN READING ALOT .So what are people having luck with.6k axels and gvwr 14000
2007.5 chevy 3500 ltz CC LB Duramax
2016 Open range 3x378
Some other toys too
43 REPLIES 43
NC_Hauler
taken wrote:
NC Hauler wrote:
Don't see what you own in your sig or your profile, but looked at some of your post..Appears it's a GD....don't know any information on it, but if it came with G rated tires or has 6,000 or 7,000# weight rated axles, then you should be fine...I have GY G614's on my 5er, which has a GVW of 16,950# and the tires work great...no problems....
Agree 100%. Have them on ours and never even think about tires. Well, except when I go on the forums...
:B."Never think about tires, except when on the forums"...yep, pretty much it:)
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
taken
Regards, Rodney
TV - 2017 F350 SRW CC SB 4X4 6.7
TH - 2015 FR XLR 395AMP
NC_Hauler
Gsport wrote:
I just replaced my tires today with G614 Goodyears.. I sure hope I get the peace of mind I'm looking for.
ON EDIT: Looked up specs and see a GVW of 16,000# and axles rated at 7,000#...you should be fine with the GY G614's...What is recommended air pressure? I air mine to 110 psi per HR manufacturer as well as GY...Works great:)
B&W RVK3600 Hitch
Gsport
MPI_Mallard
I lost a tire last fall and after a lot of research I put on four Goodyear 614 RST (235/85 R16)tires and I'm very happy with them so far, as far as Michelin is concerned I was a loyal customer for much of my adult life but last year after one and a half years and 18.000KLM's all six of my LT235-80R17 started to rot and after a solid week of fighting with them they finally settled on giving me only 70% off on replacements I'll never deal with that company again!
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blรผcher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
fj12ryder
Me Again wrote:
fj12ryder wrote:
The Michelin XPS ribs are not a true 235/85-16 and are about an inch shorter than other LT 235/35-16 tires.
That is wrong! You are confused with the Goodyear G614 that is shorter!
XPS RIB 32 inches
LTX M&S2 31.7 incles
Transforce HT 31.73
Commercial TA All Season 2 31.7 inches
R250 31.7 inches
GY G614 30.7
Chris
The original Commercial TA seems to be gone in this size, this All Season 2 is 40.7 pounds where the old TA was 44.1 lbs.
Sorry, my mistake. I was indeed thinking of the G614.
That make your day?
Howard and Peggy
"Don't Panic"
garyp4951
Get the Bridgestone R250's in a 245-75R- E and move on. These tires weigh over 50 lbs. and are built like a tractor trailer tire.
Me_Again
XPS RIB 32 inches
Transforce HT 31.73
R250 31.7 inches
GY G614 30.7
Chris
fj12ryder
Howard and Peggy
"Don't Panic"
jaycocamprs
We have a 14400 GVWR and 6K axles. Now we aren't near that heavy but with the Duravis R250's I don't worry about the tires. The Bridgestoneโ€™s were $75 a tire less than the Michelins. Yes they are expensive, but still less than half what the damage cost you.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
2naEagle
I replaced my ST235/80R 16/E Marathon's with LT245/75R 16/E Michelin XPS RIB's. Od on Marathon's 30.7" and Od on RIB's 30.6 been on for 6 1/2 Years and a lot of miles.
2020 F350 Limited CCSB SRW
2017 North Point 315RLTS
2021 Jayco Greyhawk 29MV
NC_Hauler
carpetguy2 wrote:
Did alot of checking on the michelin xps and seems to only have 235 85 16 .I have 235 80 16.Between the two sizes assuming the 85 are taller.Any one had a issue with that .
Tires i found are about 300 each.are they really that good .I know pay now or pay much later
thanks
Yes, the Michelin XPS RIBS are really THAT good...as also earlier stated by "me again" in his post the Bridgestone Duravis R250 cost less and is "just as good as" the Michelins...might want to check out the pricing on the R250's...again, you won't go wrong with either....
B&W RVK3600 Hitch
carpetguy2
thanks
Some other toys too
MrVan
Try Costco for Bridgestone R250's. $70 off for 4 right now. They will mount on your rims but they have no place for the 5th wheel to mount them on the 5th wheel so you will need to do that for yourself. Discount Tire won't mount LT ties on a 5th wheel with less rating than the ST tires already installed from the factory. Our ST tires were rated at 3500lb and many LT tires are rated at 3,000 lbs. We put the 3,000 lb LT Bridgestone R250 Duravais rated tires on 6,000 lb axle so no harm, no foul. I think Discount Tires policy is myopic in an attempt to sell Carlisle tires. I will never have ST tires on our 5th wheel again.
