Heavy duty 16in tire
buc1980
Who make heavy duty tire in size 16 ,load capacity over 3500.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
23 REPLIES 23
calewjohnson
I have a set of Sailun S637 going on Sunday. I kicked around the Goodyears, but the price is good ($1400 for 7 tires installed) and they hold the ISO 9001 and US DOT Certificates... The tire size for my trailer (235/85R16) is a steel encased tire (60lbs/tire) and 3750lbs rating per tire. Good for my 7k axles.
Of course, all that information was learned from folks on the forums.
Cale
TV: 2015 6.7 F350 CC LB 4x4 DRW with 14k GVWR option (4.3 gear), 98 gallon aux tank installed by Transfer Flow
New: 2014 Voltage 3950
Traded: 2014 Outback 323BH
Still Have: 2007 Fleetwood Nitrous 23ft Toy Hauler
Me_Again
Cummins12V98 wrote:
If you want the "best" in a G buy the GY's. Top quality, US Made. They will pay damages. Their track record since 07 has been great.
E tires I would go with Me Again's recommendations.
Say what? The tires I listed above are all Load Range G tires, rated to 3750 each.
Chris
buc1980
I use to have g614 tire befor but I give up of them when 3 of them blow up.That was back in 2005-2007.I replace them with Michelin RIB but this week one of them blow up so I want to replace with stronger tire.I like to get the 17.5 rims but I replacethe original rims (steel) with Alcoa.If anybody know a cheep place to buy aluminum rim tell me.
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Me_Again
If you are talking about for a trailer:
1. Goodyear G614 rated to 3750
2. Sailun S637
3. Geostar G574
4. Gladiator: QR35-TR(AS) Trailer Note: Most be (AS) for all steel
These are all steel ply carcass offerings rated to 3750.
Miles_Away
Are you talking about tires for your trailer or truck. Goodyear make a "G" rated trailer time for 16" wheels. CW stocks them for about $350 each. Not sure they are worth the price. If your rig came with "E" rated tires, you probably don't need go to any higher than that, unless your just looking for extra peace of mind. $tronger tires will not change your legal GVW, even if you swap out your axles and wheels to accommodate the higher ratings.
M & M :C On the road again!
2007 GMC 3500-SRW-Duramax-longbed-4X4
2008 Keystone EVEREST 348R 5th wheel
2002 SUNDOWNER gooseneck horse trailer
SH
Sailun 637
Hankook F19 will almost get you the desired rating...3330 lbs.
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo ๐Ÿ™‚
donn0128
Only one LT tire I know of. If you have 7K axles 17.5 inch tires and wheels are your best option.
MNRon
Carlisle RH load range F are the only ones I know.
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
