Help needed with 2007 Weekend Warrior FSC2800
Siberjon
Hi all,
I need some help with two things:
1) Does anyone have a digital copy, scan, pdf, etc of the brochure and specs for the 2007 Weekend Warrior FSC2800. I specifically would like to know the size of both fuel tanks, as well as the fresh, gray, and black tanks.
2) I need to replace the onboar Generator fuel tank and the Fuel station tank. Where can I buy these? I am located on the West Coast of Canada but regularly travel to Washington and Oregon state as well.
Thanks for your help!
3 REPLIES 3
lincster
Unless something chsnged between 06-07, here are my specs for my 2006 LE3505.
150 gallons fresh.
50 gallons grey.
50 gallons black.
40 gallon fuel tank plumbed to nozzle.
20 gallon fuel tank for genny.
I added another 40 gallon fuel tank and tied the 2 together.
I got the tank from weekendwarriorpartsandservice. They are in Perris CA.
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
ronharmless
SAR_Tracker
15 gallon propane capacity, 150 gallons of fresh water, 50 gallons black water and 50 gallons of gray. 50 gallon gasoline transfer station, 30 gallons gas for generator.
Clicky
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
