May-22-2017 05:17 PM
May-22-2017 06:42 PM
May-22-2017 06:23 PM
agesilaus wrote:
I would quickly drill a few small holes at the bottom of that panel
You can seal them with epoxy putty latter
CA Traveler wrote:
Have you carefully checked the inside for moisture? Especially where the wall and floor meet at the delam areas. I would certainly expect that dry rot has already started.
If you are going to salvage this RV you need to get it completely dry and leaks repaired. You are faced with a lot of work or dollars or salvage. If not the latter then immediately get the rig to an enclosed area out of the rain.
The formula: moisture + wood + no air circulation = dry rot! 😞 😞 😞
May-22-2017 06:10 PM
May-22-2017 05:45 PM
May-22-2017 05:38 PM
May-22-2017 05:37 PM
May-22-2017 05:31 PM
