Hitch rails on used TV
hyattjlbb
Upgraded the TV and it already had the rails for the hitch mounted in the bed. Here is the problem:
I attempted to drop my hitch in to get it out of my garage and the rails do not line up perfectly. I can get the front or rear dropped in the rail but the other "pegs" are off by about a 1/4".
Can I loosen the bolts on one of the rails to adjust it? Would there be enough "play" to move it? Maybe you guys have a different solution? Figured I am no the first guy this has happened to.
Jamie - KE0NSE
2011 Jayco Eagle 365BHS
2019 Chevy Silverado CC SRW 3500HD, Max & Alli
Beautiful Wife of only 24 Years:B
Boy at College - 21yrs,:C
Boy - 15yrs:p
11 REPLIES 11
hyattjlbb
Anti-Theft, Love it!
Jamie - KE0NSE
Boy - 15yrs:p
DennisG9
Your hitch isn't stuck. It's one of those undocumented features, an anti theft device for your hitch!
TheAmRheins
After towing a few times the rails will probably relax and reset themselves to your hitch.
Ken & Kathy
Ruben(the cat)& Tiadora (nother cat)
2003 Chev 3500 D/A Dually
2009 Landmark Augusta
Bill1374
You might be better off slotting the rail bolt holes.
Bill
KZ Montego Bay in Florida
Rockwood lite up north
2016 HD Street Glide, 12 Fatboy for cruisin
hyattjlbb
Well, good news, bad news. They were RBW rails as I went to the RV repair shop here in town to get another opinion. We loosened both rail bolt sets and each rail moved about 1/4".
Good news is that we got plenty of play to allow for the roughly 1/16th of an inch that I needed. Hitch is now seated!
Bad news is that after the hitch was seated we tightened the bolts back up and they snugged back to where they were. Hitch is now permanently mounted unless I were to pry it back out. But hey, I can tow now!
So new question, would I dare grind about 1/32nd off the two trouble feet or would this hurt the hitch? Not much more than grinding the paint off.
Jamie - KE0NSE
Boy - 15yrs:p
Old-Biscuit
Are those rails the right ones for your hitch?
Were those rails installed in proper position/spread for your hitch?
Hitch may fit the rails but that doesn't mean when they were installed that the spread for the hitch used was the same as your hitch.
Nothing to lose by loosening the hold down bolts on both rails....but they may still be off.
2-MTnesters
Please keep us updated on this. I hope it works out for you. Tim
The Webers
Me- Tim
DW- Dea
Pooch- JoJo boxer/lab mix
2010 Keystone Montana 3400RL Hickory Edition "The Taj Mahaul II"
2004.5 GMC Siera 2500HD SLT CC 4x4,6.6 Duramax/Allison, 3:73 gears, Firestone air bags, Reese 16K slider, TFI 45 gal fuel tank, Rhino Liner
hyattjlbb
Ahh yes, both rails to get double the play. I will give it go this afternoon, thanks!
Jamie - KE0NSE
Boy - 15yrs:p
2-MTnesters
After looking at These instructions for your hitch it doesn't look like there is any adjustment in the feet on your hitch. You might try loosening the bolts in BOTH rails, install the hitch, then retighten all bolts. there should be enough 'play' in the bolt holes to allow the hitch to properly fit into the rail slots. Hope this helps. Tim
The Webers
Me- Tim
DW- Dea
hyattjlbb
Sorry, some hitch info could have helped. Non-Slide RBW X-16.
Jamie - KE0NSE
Boy - 15yrs:p
2-MTnesters
Which hitch do you have? If you have a slider hitch there is adjustment for the feet that go into the slots in the rails. At lease there is on my Reese 16K slider. Tim
The Webers
Me- Tim
DW- Dea
