How much safety I can tow. Please help check the numbers!
Chuck___
I tried to find the safe tow numbers that my truck can safety handle before I purchase a newer 5th wheel. Below are some of the web sites and resources I tried to fine the correct information from.
1. My truck: 1999 Dodge Ram 2500 3/4 ton, Quad Cab 2-Wheel Drive, 5.9L, I6 Cummins Turbo Charged Diesel, Auto Trans, 3.54 rear end.
Information from the driver door: GVWR=8800; Front GAWR= 4410; Rear GAWR=6044; Tires on truck now: LT245/70 R17, Load Range E, Max Load Single=3000 lbs. Note: Several years ago I have to have the transmission rebuilt. Had it rebuilt extra heavy duty with trans. cooler.
1a. Data from truck operating manual: Note, for Auto transmission list only 4.10 alxe ratio no 3.54: GCWR=18,000, Max Trailer Wt.=12,000. For 3.54 rear end, What is the GCWR rating?
1b. Pin weight for truck: GVWR=8800 X .25=2200 lbs. Am I calculating the pin weight right?
1c. Pin weight for trailer: Max Trailer Wt. 12,000X.25= 3000 lbs.
2. Looked up information on VIN Decoder: VIN# 1B7KC2360XJ636854.
2a. Wt. Distributing Hitch-Max Trailer Wt. = 10,000 lbs.
2b. Pin weight using VIN data: Wt. Distributing Hitch-Max Trailer Wt. = 10,000X.25= 2,500 lbs.
3. Measured weight from scales:
3a. Front GVWR= 3,880 Rear GVWR= 2,720 Total weighted truck @ scale=6,600.
3b. Pin weight: GVWR=8,800-scale total weight6,600=2,200
Summary: So want numbers do I believe? How heavy of a 5th wheel can I safety tow? Please show me if I am calculating Pin weight the right way and other calculations. What is the heaviest 5th wheel I should pull; dry weight and GCWR weight of a trailer?
You look up different web site and youโ€™ll get different numbers! I know I need to take into account the weight of the driver; plus passages and extra weight in the tow truck. Could be an extra 600 pounds off the pin weight calculations. Also not to go by Dry Weight of the trailer. Got to figure in water weight of 8 lbs. per gallon and extra weight of food and supplies. Could weigh up to or more than 1,500 lbs. to 2,000 lbs. additional weight in the trailer.
PS: Like to buy a used 2007 Mobile Suite Model 32 TK3 a local person has. Dry weight is advertised @ 11,500 lbs. But, Luxury 2007 Mobile Suites 32 foot fifth wheel self-contained very clean with only 5,000 miles is in my opinion way over priced at $54,999.00. Just a pipe dream!
Chuck
17 REPLIES 17
laknox
ScottG wrote:
With your gearing the tow capacity is closer to 10K# - gearing makes a big difference.
Honestly I think that's an awful lot of trailer for your 3/4 ton.
Also the loaded pin weight is going to be well in excess of your max load carrying capacity which is around 2K#. Then there's the weight of anything you carry in the bed and passengers.
I'm sorry but I think you need more truck or less trailer.
I agree; less trailer or more truck.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
mdamerell
Was the whole family in the truck when you weighted it? Well if you don't have a hitch in the truck yet you are at 2,200 - 200# = 2,000# pin weight.
2,000# / 20% = 10,000# loaded weight. So probably around 8,500# max dry weight. So look at "Half-ton towable"
Not really a good truck to haul a 5th wheel. Trucks prior to 2005 have much lower numbers than the new trucks.
2012 Sundance 3100RB w/Reese Goose Box
2004 Ford F350 6.0 L PSD, CC, DRW, long bed, B&W drop ball hitch, Firestone Ride-rite air bags.
ScottG
