Toyhauler with outdoor kitchen
Brandon327
Does anyone make a toyhauler with a outdoor kitchen? I would like at least a fridge and sink.
2013 gmc 3500 hd cc Drw 4x4
2016 Dutchmen voltage 3990
15 REPLIES 15
MadMav
http://www.cyclone-trailers.com/images/cy3712ck-flpln-spec.jpg
Mav
"A fifth wheel trailer is a bi-level towable mobile home."
bkirkpatrick
msmith1.wa wrote:
I have not sent one. In case you did not know all the fridges in the outside kitchens that I have seen are 120v only.
I know, I saw several of them and I was like WTF. Can't believe someone does not install a propane one.
englishmatt
Hi there...the Crossroads Elevation TF 4012 and several of the new Elevation line have outdoor kitchens.
wildcatwmn
We've been looking for the same. My hubby is a BBQ chef and having the sink and fridge outside would be great. We hardly use the inside kitchen as it is. So far the Puma Unleashed 25TFS looks to fit the bill. The only downside is they put the kitchen under the master bed making it short. Normally, a few inches short wouldn't be a problem but he is 6'6" so we're still contemplating. I do love everything else about this TH.
flat_twin
1L243 wrote:
An outside kitchen that can be locked away or closed up would be the the way to go. Some National and state parks I have stayed in will not let you leave cooking stuff out when you leave your camp. Rangers will actually go in and remove the items from the campsite and you will have to pick them up at the rangers office...
Policy regarding bears or other animals? If we were in bear territory nothing would be left outside.
Brandon327
I don't want a stove and all that I want is just a sink and fridge.I don't care if the fridge is 120. Most everywhere I go has hookups. I usually take a grill.
1L243
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
Strabo
Everything left outside while camping is covered in 2" of dust after the first day.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
nayther
flat_twin wrote:
Strabo wrote:
Last i checked i was the out door kitchen. ๐Ÿ˜‰
That's true!
A table, Rubbermaid tubs, a cooler and a white gas stove. Ta da!!!
We just added a Blue Sky Kitchens chuck box to our toy hauler last year. It was extremely handy to have with nearly all the kitchen you need in one box, plus the work surfaces it provides.
A table, the chuck box and one big storage tub with all the large cooking gear and stove makes a very usable outdoor kitchen.
Good grief! Might as well just have a box to tow and sleep in if you drag all that******along! Me, I HATE set up and break down and do everything possible to take as little as possible (but that hasn't worked out too well either).
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
flat_twin
That's true!
Post modified to avoid hijacking the thread. Thanks
deltabravo
During my many trips transporting RVs, all the ones (non toy hauler) I've run across with outside fridges are the same as mentioned above - 120vac... which means unless you are on shorepower, or have a huge solar array and a big battery bank with inverter, the fridge isn't much use.
Strabo
Thats nice, you loose the storage tho but i like it.
souraider
Stealth makes this one.
AK2612
'17 F350 STX 6.7
'15 Stealth WA2313
'20 Can Am Maverick Sport 1000R
Strabo
