โDec-08-2016 04:46 PM
โDec-16-2016 05:09 PM
โDec-13-2016 11:46 AM
RVA Jeff wrote:
I think I'm just going to use the leveling system and rotate the tires a bit and then put them back down
โDec-13-2016 10:46 AM
โDec-13-2016 09:43 AM
โDec-13-2016 07:44 AM
BarneyS wrote:
Before going through all the trouble of blocking, leveling, and taking the tires off, I would check with the campground first regarding the tires. Some campgrounds have rules requiring all RV type trailers to have the wheels and tires installed.
Barney
โDec-13-2016 07:43 AM
aruba5er wrote:
blocks would hold it up forever but make sure you don't put them sideways. They are not very strong used on the side. Web verticle, like you would put morter on. I'd start by putting down a piece of 2x10 or 12,to provide a larger surface, then build up the height with block and finish off with whatever 1x treated lumber needed to make level. then lower the fiver down to the crib you've made. I'd just cover the wheels with a good cover. Forget about moving it. Tires are going to rot regardless, later rather than sooner by covering them.
โDec-13-2016 06:16 AM
โDec-11-2016 12:35 PM
โDec-11-2016 12:30 PM
โDec-10-2016 11:30 AM
md_procouple wrote:
My two cents... I wouldn't use cinder blocks they can be a bit shakey after a while esp. after snow etc. I would use pressure treated 4x4's or 4x6's. If you do not have a place to store the wheels if you remove them. simply buy the wheel covers at Camping world or Walmart.
โDec-09-2016 09:04 PM
โDec-09-2016 03:19 PM
โDec-09-2016 11:12 AM
โDec-09-2016 10:20 AM
