Landing gear
ret-miner
Having a bad hip and back is anybody build a block to put under the landing leg so a person don't have to get down to release the leg slide to pin it in place. thinking of building one10in wide by 12 long by 9in high would save me from getting down and no wife can not do it bad knees,any feed back will be appreciated
4 REPLIES 4
Barkie
I don't recommend using high blocks under the landing gear of a fifth wheel. I witnessed a guy bump his hitch while trying to connect and knocked the landing gear off the blocks. The trailer landed on his truck and dented the body. If the landing gear falls off a 8 inch block then it drops 8 inches onto your truck. A simple pad under the landing gear is fine. Sorry this does not help you avoid bending over to place your landing gear but will help you avoid fixing your pick-up!
Old-Biscuit
I just use the 'handle end' (loop) on my awning rod to pull pin out...then let them snap in place
I also use the 'hook end' of awning rod to lift the inner leg back up
Not a fan of high blocks under landing gear legs.....wobbly
I do use a board under them to spread weight
the_bear_II
I've seen blocks like that RV'ers have built. The one I liked the most the RV'er had added a staple shaped piece of steel rod that stuck up from the block at a slight angle about two feet. He used this to maneuver each block into place. He hardly had to bend over.
korbe
I always get down on one knee for that process. I haven't figured a way to make it any easier - and my mind is always trying to think of ways of doing tasks easier. ๐Ÿ™‚
