Leaf springs new best brand triple axle advice
rockwind1
2007 attitude FSAK 33’ toyhauler. Weighs about 11k withf tanks full. Been having bad luck with this trailer lately, I just noticed that one of my leaf springs, the front axle, the shackle had somehow flipped upside down, which Squashed the big rubber bushing and the leafspring looks kind of reverse curved now, as well as its corresponding leafspring on the other side. They are four leaf. The trailer is a 33 foot attitude toy hauler. I think all the axles are 5080 pound axles.
A shady trailer repair place said they wanted 2 thousand dollars to put all new 6 leaf springs on all axles along with new shackles. My question is if I replace the leaf springs on the front axle do I have to replace all the leaf springs on the other axles? And second question is what is the best brand of leaf springs to buy? And where is the best place to buy them? Was the trailer under Sprong in the first place with the four leaf type leaf springs? Should I get six leaf type for replacement? Or can I get away with just replacing the Messed up ones?
23 REPLIES 23
rockwind1
bucky wrote:
I don't think that price is out of line for the area. Is the shady opinion based on the price or something else?
The equalizers are easily flipped. Letting us know the age of the coach and the loaded weight from a certified scale will help us help you.
Sorry. It’s a 2007 attitude fsak33’ toyhauler about 11k w/full tanks. Triple axle as Mentioned above. All the leaf springs have four leaves in them. If I just replace the front ones which look kind of flat now compared to the others do I have to replace all the springs?
Ron3rd
Or Dexter Torflex like I have on my Rockwood
Equilizer Hitch
Honda EU2000
TXiceman
Truth be known, the best thing to do is get rid of the springs. Go with a Mor/Ryde IS system on the trailer. Not cheap bur well worth it.
https://www.morryde.com/products/independent-suspension-system/
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
azdryheat
Did you fix the shackles on the front axle? If I lift my tires off the ground, triple axle, sometimes the shackles will flip. Not a big deal to put them back to normal position.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Ron3rd
Any decent mechanic can do this job. You dont need a "trailer" repair shop. In fact some of those so called Trailer/RV repair shops are terrible. There's nothing magical about trailer leaf springs. Heck, I've even done the complete swap, HD equalizers, shackles, leaf springs etc myself. A good trusted mechanic is a valuable thing.
Equilizer Hitch
Honda EU2000
time2roll
I bought mine here and replaced them myself. Added a Dexter HD shackle kit at the same time. Takes a bit of strength but the work is low tech bolt-on. I went up a bit in weight rating and the trailer rides better than ever.
http://www.stengelbros.com/trailer-suspension-parts/trailer-leaf-springs/
Tyler0215
Why would you even consider a "Shady" repair shop?
JIMNLIN
Rockwell American Axles....however for just replacing spring packs go to your axle mfg for actual answers about what works and what doesn't.
bucky
Puma 30RKSS
