Leak in roof @ A/C
freewayrandy
Just noticed the other day I have a leak in the roof in the garage. The water is dripping from the A/C panel that has the foam air filter in it.Anyone experience this? Any clues as to where to start my search for the leak? :?
2022 Chevy Silverado 2500 HD Duramax/Allison, 2024 Cougar 27SGS
3 REPLIES 3
Y-Guy
Moderator
Moderator
Closing this thread, please do not post the same message in multiple forums as per forum rules. Thanks!
You can continue the discussion here.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
freewayrandy
Thanks for the good info Dusty. Only when raining.
baker01
Does this only happen when you have been running the A/C? Or after wet weather? If after wet weather, the AC upper unit has a gasket between the unit and the roof. The unit is tightened to the roof via four bolts from inside the RV. To access the bolts, the lower unit inside the coach needs to be removed. Best case scenario tighten bolts and the leak stops. If leak does not stop replace the gasket. For bolt torque specs Check online for the units installation manual. If it happens when running the unit it could be plugged drain holes. Pull upper units cover inspect and clean. There are some good youtube videos on how to proceed under RV AC maintenance / RV AC leak / RV AC gasket.
Dusty & Mikki
Sirverado 3500 Dually 4x4
2019 Fuzion 369
2018 XPT
2006 Honda CRF450X
2006 Rhino 660
Harley FXSTC
