Leveling Toy Hauler For Weight Distribution Hitch
shoots
hi all, am trying to level the trailer so we can setup the hitch height for the weight distribution assembly. problem is, we have to raise the front of the hauler to get the inside floor level. we put the leveler to the tongue and the front is higher?
which should we level to get an accurate tongue height measurement? level the tongue or level the inside? confused ....
2008 Fleetwood Redline 19ft Toy Hauler
3 REPLIES 3
Chuck_Gail
rrupert wrote:
Assuming you are sitting on a perfectly flat surface and the frame is straight the whole length of the trailer, measure from the surface up to the frame both front and back and adjust the tongue height until they are both equal.
Yup, or as much as 1.5" LOWER in the front as measured from front and rear frame to ground.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
2010 Outback 230RS Toybox, 5390# UVW, 6800# Loaded
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories
I can't be lost because I don't care where this lovely road is going
rrupert
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
beemerphile1
I would level the floor since the floor sits directly on the frame.
I hope your tongue isn't bent.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
