โNov-12-2017 06:48 AM
โNov-26-2017 03:21 PM
ckwizard777 wrote:Askwines323 wrote:
Thanks, guess I'm looking for comparison between an I beam vs. A box frame. Which is considered better and why.
Stacked box frames are what I prefer as they will be considerably stronger with a lot less frame flex that your typical I beam frame.
DRV uses this type of frame and the old Sunnybrooks use to have this type of frame but no longer do.
Now many of the other high end builders will use a 12 I beam frame but will also weld a heavy wall square tube along the bottom of the I beam to beef it up and reduce frame flex, I would be ok with this set-up also.
Good luck
โNov-20-2017 02:56 PM
โNov-20-2017 02:39 PM
โNov-20-2017 08:49 AM
โNov-19-2017 07:00 AM
โNov-18-2017 01:01 PM
โNov-18-2017 06:10 AM
โNov-18-2017 06:00 AM
โNov-17-2017 06:32 AM
โNov-15-2017 08:02 AM
Askwines323 wrote:
Starting to research 5th wheels. I'm following the advice of many to focus on the build first, not the bells and whistles.
I'm trying to find information on comparisons of frames and suspensions available. Tried searching but no luck.
Thanks
Alan
โNov-14-2017 01:17 PM
โNov-14-2017 01:13 PM
โNov-14-2017 03:00 AM
Butch50 wrote:
When NUWA was still in operation I believe a lot of their frames were made by Young's Welding. Very good frames. Young's Welding just happens to be located in Chanute, KS. Pretty handy for NUWA.
โNov-13-2017 04:20 PM
