Looking for used utility ATV recommendations
RedRocket204
So, looking to see if a few of you can help share some of your expertise with general recommendations since I am a UTV/ATV noob. In about 6 months I will be looking to buy an atv, most likely used via private party. I am doing a bunch of online research but continually run into a lot of "what I bought is the best" mentality. In my area, it seems that right now is not the best time to buy used as hunting season is quickly approaching as well as winter. I also want additional "disposable" cash for the purchase.
Primary use for this machine will be utility, snow plow and towing using a rough-cut mowing deck on my property. Mowing deck will probably only be used twice a summer. Property is not huge but big enough for a riding mower and there is some off-camber sections but nothing significant. Area to be plowed is relatively flat but the bigger issue is right now it takes a while with my snow thrower. I figure if I buy the right machine and accessories, should help minimize time spent plowing/mowing. Using it for jeep trails/exploring will be something I would like to do but is not the priority (have to remember justification for the wife ๐Ÿ˜‰ ). My house is at just under 8k ft. elevation and jeep trail elevations would exceed 11,500 ft.
I'd like to limit my budget at $6k. I also understand that it is recommended for plowing, to try and purchase a 500 (+) and make sure 4x4 is at least available. Obviously I would be looking for an utility model and not a sport model. Reliability is another priority. So, insight into different options and models are something I am asking about. I do understand FI and power steering might be nice but the cost starts going up for those options. Are they worth it and/or really needed are just some questions below:
FI?
PS?
Factory or aftermarket winch (for slow plow)?
Snow plow type recommendations?
At what point is mileage/hours an issue for reliability (if history for proper service has been followed)?
Used models that seem to come up and appear reliable, based upon noob research:
Honda Foreman
Yamaha Grizzly
Looking for additional model recommendations, thx.
I love me some land yachting
31 REPLIES 31
romore
Any of the major brands will give good service provided they have been well maintained and not been abused. Snow plowing is hard work and requires a stout machine with good power. Stay way from the clones such as Baja, they are flimsy and parts are a bear to get.
None of the atv people make their own accessories, they all out source. I am familiar with Swisher, they make good stuff, although others are out there. Warn supplies a quality winch along with the mounting plates and wiring, a lot simpler than fabbing your own. A tip on plowing, get off the switch as soon as the blade is raised or you will be repairing broken cables.
coolbreeze01
The 1987 250 Suzuki 4x4 I bought new is still running well for the current owner, as is the 2000 Honda Rancher 4x4 I bought to replace the Suzuki.
At your altitude, fuel injection is worth it and I really enjoy the power-steering on my current 2010 650 Can-am Outlander. Hold out for a well cared for unit. Good luck.
2014 Sandsport 26FBSL
